Caporegime
- 13 May 2003
- Warwickshire
You're all making it sound like the difference between a manual and an auto on a Picasso, is the difference between breaking a hill climb record and barely spluttering up that hill. It really isn't so dramatic, even with a loaded car. You just get in the slow lane and wait for the flat bit, just like you would with the manual, except it might take you 0.5 seconds more to get up said hill.
That's the way you drove it, you mean. It's not (or shouldn't be) difficult to adapt your driving style to an autobox.
All gearboxes sap power. The question is, is the power that the autobox saps so much more significant than that lost in the manual. For your average Picasso driver, no, of course not. An autobox doesn't instantly transform this car from acceptable to unacceptable as you are making out. It's a simple preference.
Yeah, cause a leather interior has so much to do with the suitability of an autobox. Back to your advanced Bentley training, I think.
No-one is (or should be) arguing that an autobox is more expensive to fix if something goes wrong. That's obviously the case. But to try and pretend that they turn a 1.6 into something barely driveable smacks of failing to consider the reality, for the average Picasso driver that can't be arsed to changed gear.
It wasn't broken, that's the way they drive
[TW]Fox;17853477 said:It's nothing to do with that - autoboxes sap power, power a 1.6 litre engine doesn't have. The result is a frustrating combination of dreadful fuel economy and a ridiculously unresponsive engine
It will. Especially when what little power it does have is put through a slush box. The opinion that they will not is laughable tbh.
As for "Manuals go wrong also" being a counter point for the proven "Automatics break more often and are more difficult to fix" - LOL.
Stripping a manual box is utter child's play compared to cracking open a modern automatic transmission and playing with it's guts. Seriously, I still have nightmares.
Automatics are cool in their place - Behind a powerful engine with 6 or more cylinders in a car that has a leather clad interior and preferably wood grain trim. Putting them anywhere else is against the laws of nature.
