Krypton Rampage Extreme Intel Core i7 950 3.06GHz @ 4.20GHz OC Bundle
wnb
wnb
27 Feb 2004
What would be the temp range on the cpu? Core temps are reporting it as low 53 and High 88. Its just that I read in the reviews for this product someone was getting 25\35 idle and someone says it shot up to 65 saying maybe he does not have enough cooling.
I have just run prime and it crashed after about 5 minutes with a temps at a max 99:(
Sounds very strange. Are you sure you have mounted the CPU cooler correctly? Removed the plastic from the bottom etc?
If it hit 99 then I suggest looking at your heatsink mounting and try doing a full remount with new thermal paste.
As for someone getting 65C and thinking he may not have enough cooling - please ignore this. A 4.2GHz i7 with an air cooler is expected to be in the 80s when fully loaded - but if it is the high 90s then something is off.
Early test show while running prime blend, I am getting a peak temp of 77 which is much better than the 99 i was getting yesterday.
:) I have also added an extra 120mm fan so that I now have 4x120mm fans at the front, back, top and one on the cooler. I can add one to blow\exhaust over the hard drives if needed.
