Yes please, was what I wanted to know initially. Which HD6870 is the fastest?
Done, it says it will verify it etc.
6870 is 6870 no matter what brand, so whichever one that has the highest factory overclock will be the fastest (in this case I think it is the XFX BE). However, manufacturer tends to charge a small premium for the small factory overclock, of which you can easily do yourself using application such as MSI Afterburner. You can get the following for £15 less, plus a Modern Warfare 2 Voucher Code for the full game:Yes please, was what I wanted to know initially. Which HD6870 is the fastest?
My bios will appear here, not there yet though
http://www.techpowerup.com/vgabios/...cturer=XFX&model=HD+6870&interface=&memSize=0
Overclocks to 1000/1200 easily
Dave, I've added you on msn in the hope that you can send me the bios file. I will then drop a copy onto my web server for download until it's available on techpowerup's site if that's ok with you?
I've uploaded it anyways mate, this is what you want yeah?
http://www.ukweatherworld.co.uk/Dave/Barts.bin
Very nice indeed - works fine on my Sapphire card. I was previously using the HIS bios (920/1120) and got a Heaven bench of 938 at 1080p using the stock 10.10 drivers. Using the XFX bios kindly supplied by dave_beast I get a Heaven bench of 964 with the same settings.
And yes I know I could get more if I use afterburner etc but i like to fire and forget so flashing the bios is a neater solution for me!
Thank you Mr Beast! As a well known supermarket likes to say - every little helps!
So I guess the answer to the OP is whatever 6870 card you buy should it happen to accidentally get flashed to the XFX BE bios will be the fastest![]()
Guys, i've made my mind up. I am going to buy a HD6870. On overclockers site this card looks the fastest.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-190-XF&groupid=701&catid=56&subcat=1866
I have seen some 2GB ones on Fleabay but they are from over seas.
Sois this card the best one out there atm? out of the HD6970's
Cheers.
Atiflash for dos version. http://www.octeamdenmark.com/download/doc_details/60-6870flash.html
