*****PAYDAY WEEKEND ONLY DEALS - STARTING NOW!!*****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Right, its that time of month, were all getting paid and those of you who have not spent all your money on a PS3 and GT5 were gonna be posting some extremely tempting offers over today and tomorrow.
The deals will start now and end 5:30pm today and shall re-commence at 9:30am tomorrow and end Friday 5:30pm. All prices will hold whilst stock last or until Monday morning.
To get things started I have a pair of amazing deals for you all to get your teeth into:-
Patriot Viper 2 Sector 7 6GB (3x2GB) PC3-12800C8 1600MHz Triple Channel Memory Kit @ £89.99 inc VAT
The Patriot Viper II 'Sector 7' Series, part of the Extreme Performance (EP) Low Latency line, is the ultimate performance memory solution for the Intel® X58 chipset and Core??? i7 processors. The Viper II 'Sector 7' series are built using only the highest quality pre-sorted IC's available and are subjected to rigorous testing and validation on the X58 platform to achieve optimized performance and maximum quality. These modules are engineered to reach PC3-12800 (1600MHz) at 8-8-8-24 timings and are available in 6GB kit capacity (3 x 2GB). Each module is 100% hand-tested for quality assurance and is backed by a full lifetime warranty and industry leading customer service.
Features
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (8-8-8-24)
- 1.65V
- Equipped Patriot Viper Heat Shields with integrated ACC (Aluminum Copper Composite) technology
- Lifetime Warranty
- XMP Ready for Core i7 Processors
Was [99.99] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
BenQ G2222HDL 21.5" Widescreen LED Monitor - Black @ £109.99 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2222HDL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 504.6mm x 392.9mm x 175.0mm
- Weight: 3.8kg
- Warranty: 3 Years On-Site
Was [£119.99] Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
These are just a taster of whats to come, the Patriot memory is an incredible deal, it operates at 1600MHz with CAS 8-8-8-24 timings which will make sure your memory is not the bottlenock in your system. The BenQ 22" LED monitor gives fantast contrast and vivid colours making games come to life. :)
ROUND ONE of deals will appear shortly!
Looking forward to it gibbo, lets hope its not the same old stuff with £3 off, if you want peoples money this time of year its going to be some proprer bargins like you did back in 2009 ;):p
We shall do our best!
You have to remember most of our prices are already pre-discounted. ;)
Bah if I had the money I'd have ordered 3 of them cases (edit, monitors) :mad:
Then again, I'd buy a 580, lian i pc a70 + 2 loops if i had enough money for 'em :D
