Today Only, we have some best value prices in the UK. This is one not to miss out on, make sure you upgrade your computer with these incredible products. Hurry as deals end when allocated units run out!
Western Digital RE2 500GB SATA-II 16MB Cache - OEM (WD5000YS) @ £19.99 inc VAT
With 1.2 million hours MTBF at 100% duty cycle, 16 MB cache, up to 500 GB, NCQ, RAID-specific time limited error recovery (TLER) and best-in-class vibration tolerance, WD RE2 7200 RPM SATA hard drives offer the best combination of reliability, high capacity and performance for RAID server and other demanding write-intensive applications. Backed by a 1-year warranty.
- Capacity: 500GB
- Cache: 16MB
- Interface: SATA-II
- Spin Speed: 7200RPM
- Seek Time: 8.7ms
- Enterprise class drive
- Warranty: 1 Year (Clean Pull)
Only £19.99 inc VAT.
ORDER NOW
OCZ Gold Low Voltage 12GB (3x4GB) DDR3 PC3-10666C9 1333MHz Triple Channel (OCZ3G1333LV12GK) @ £164.49 inc VAT
Addressing the never ending need for greater amounts of system memory, OCZ’s newest Gold Series 12GB Triple Channel kits support the latest memory-hungry applications and games, offering superior performance gains and maximum multi-tasking productivity. Ideal for workstations with 64-bit operating systems, the OCZ 12GB solutions allow users to take advantage of high density memory configurations when working with intensive design and multimedia applications.
The Gold Series 12GB kit is designed specifically for the Intel® Core™ i7 processor / Intel® X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 12GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency.
OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility. All Gold Series kits are 100% hand-tested and backed by the OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 9-9-9-20 (CAS-TRCD-TRP-TRAS)
- Available in 4GB modules and 12GB kits
- Unbuffered
- Gold Layered Z3 XTC Heatspreader
- Optimized for X58 Chipsets / Core i7 processors
- 1.65 Volts
- Lifetime Warranty
Only £164.49 inc VAT.
ORDER NOW
- Capacity: 500GB
- Cache: 16MB
- Seek Time: 8.7ms
ORDER NOW
- 1333MHz DDR3
- Unbuffered
- 1.65 Volts
- Lifetime Warranty
ORDER NOW
