Hello
just a word of warning on anyone buying a Titan Fenrir Evo. When screwing on the "thumbscrews" I made the mistake of using a screwdriver to tighten them and ended up on one of them snapping off the top thread of the upright as I screwed it too tight.
Yes I admit they have cross section on top for using a screw driver with but its best to tighten them with your fingers!
Luckily I had some spare bits from my old watercooling setup and used a bolt, nut, couple of washes and cut a nylon spacer to the same length as the original metal uprights. Worked a treat.
