One thing you should be prepared for is loading stutter, the gamebryo engine as it's implemented in Oblivion has major bottlenecks when loading new geometry, you could have the fastest pc on the block and it's still going to stutter when entering new cells.
http://www.tesnexus.com/downloads/file.php?id=23208
That mod greatly helps to reduce the stuttering (though I doubt anything will ever completely eradicate it) and also fixes a lesser known issue where the engine actually runs at 64hz, so without this mod (or a monitor that supports 64hz vsync) you will never get that lovely smooth vsync you get in other games.
Enjoy![]()
I remember having pretty bad stuttering with SLI 8800GTX's in Oblivion. I upgraded my oldish Seagate raid array to a fast Samsung F1 drive and the stuttering seemed to disappear.
The unofficial patches, Oscuro's Oblivion Overhaul (OOO) and Martigen Monster Mod (MMM) are the big ones I remember. Also get "quest reward leveler", and try out some of the companion mods (theres one for chuck norris!).
OOO sorts out the screwy levelling system, and MMM adds tons of extra monsters for you to fight..... most are of such quality it's impossible to tell what's part of the mod and what was made my bethesda.
A lot of oblivion's scalability comes from it's mods. Your pc won't break a sweat with vanilla, but having the extra power will allow you to install high-res textures and mods which increase the number of npc's.
Cheers, jimbob27.Will have a look out for those ones.
