i7 980X @ 4.6GHz at 0C Water-Cooling!
it's just chilled water. With peltiers, not the most reliable and the pelt's have to be the right wattage.
I thought they had made some condensation proof tubing for a moment, this is nothing new.
Unreliable in what sense? I believe peltiers to be inherently more reliable than refrigeration and exactly as reliable as water cooling.
Condensation proof tubing exists, trace heating is probably the easiest approach.
You can't run trace heating in a PC. You need uniform heat to prevent condense forming after dew-point has been reached. I've been trying to develop a system for years, but other than greasing the mobo up there's always a risk it will short out and go bang. Pelts are a notable tool, but given the energy they require, a pelt array uses ridiculous power when compared to phase-change, and you only need one drop of water in the wrong place on a pelt and the whole cascade stops working when one wafer drops out.
That's interesting. I'm pinning my hopes on either trace heating or oil submersion to avoid condensation, and feel considerably more optimistic about heating. If you'd critique the following I'd appreciate it.
What I have in mind is a small pipe (<=10/8mm) with cold water running down it, then a layer of cladding, then wire heated electrically, and the entire thing stuffed down another pipe. So it's not exactly small in terms of diameter, and not very flexible either, but it's my best idea so far. The cladding isn't needed, but it'll significantly improve overall efficiency. It needs some means of distributing the heat from the copper layer to avoid cold spots, and in truth I haven't checked whether the conductivity of the outer tube is adequate for the task yet.
There's significant problems with insulating a pump & the cpu block too, which I haven't made much progress with. The tubing idea still needs some calculations, but initial results based on Fourier's law in 1D were promising enough that I've put it to one side for now.
