- 23 Apr 2009
- Cheshire
I've read that the Sandy Bridge CPUs won't overclock due to the architecture. If this is so, it seems while they might be 10-20% faster than the current equivalent CPU at stock, will they perform worse than a healthily overclocked CPU from the current generation??
As it stands the standard 1155 CPUs will not overclock in the way we normally do it (increasing the bus speed) as it uses a common bus that cannot be increased by more than a few %.
However, intel are releasing "K series" chips which come with unlocked multipliers - so these can be overclocked by raising the multiplier (and core voltage etc.). Going by past experience with Intel chips with unlocked multipliers - I would guess that it will be possible to overclock these chips very far - at least to the point where top-end air cooling is limiting the overclock.
According to their roadmap these chips will be at the same pricepoints as existing top-end i5 and i7 s1156 chips.
