*****1920x1200 26" Iiyama Monitors IN STOCK & 27" Bargains!!*****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Well we know how much our customers preferre monitors based on 1920x1200 resolution for that extra screen area but they are so hard to get unless your spending £400 plus on the DELL IPS panels.
Well Iiyama have delivered the goods, we have a limited stock of the amazing 26" E2607WS that support 1920x1200 resolution.
Iiyama ProLite E2607WS 26" Widescreen LCD Monitor - Black @ £269.99 inc VAT
The new flagship product from Iiyama is the E2607WS, a High Definition, 2ms 26” LCD solution perfect for today’s demanding applications. Superb colour quality is achieved by a 4000:1 Advanced Contrast Ratio. The OptiColour features allows quick and simple adjustment of the colour settings to suit the application or mood. 5 Watt speakers offer Stereo Audio performance well above the average multimedia display available today. The three input configuration of HDMI, DVI and Analogue guarantees compatibility with the flexibility to switch between multiple sources.
- Screen Size: 26" Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 4000:1
- Brightness: 300cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/150°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- Dimensions: 597.5mm x 460.5mm x 238.0mm
- Weight: 8.3kg
- Warranty: 3 Years On-Site
Only £269.99 inc VAT.
ORDER NOW
Iiyama ProLite E2710HDS 27" Widescreen LCD Monitor - Black @ £249.99 inc VAT
The Prolite E2710HDSD 27” LCD Display features a stunning 2ms Response Time and a High Definition 1920x 1080 Resolution. The 20000:1 Advanced Contrast Ratio and 400cd/m² brightness offer the user clear and vivid images, and the DVI, D-Sub and USB connections ensure compatibility across a range of devices including games consoles and work stations.
- Screen Size: 27" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 20000:1
- Brightness: 400cd/m²
- Viewing Angles (H/V): 170°/160°
- VESA Compliant
- Dimensions: 642.0mm x 438.5mm x 210.0mm
- Weight: 6.9kg
Only £249.99 inc VAT.
ORDER NOW
Iiyama ProLite B2712HDS 27" Widescreen LCD Monitor - Black @ £279.99 inc VAT
The Prolite B2712HDS-1 27” LCD Display is currently the largest screen offered by Iiyama. It features a stunning 2ms Response Time and High Definition 1920x1080 Resolution. The 50000:1 Advanced Contrast Ratio and 400cd/m² brightness offer the user clear and vivid images, and the HDMI and DVI connections ensure compatibility across a range of devices including games consoles and workstations. The ProLite B2712HDS has a height-adjustable stand with up to 30° rotation and up to 20° tilt.
- Height Adjustment: 85mm
- Swivel Stand: 60° (30° Left & 30° Right)
- Tilt Angle: 20° Up & 3° Down
- Contrast Ratio: 50000:1
- VESA Compliant
- Dimensions: 644.0mm x 422.5~507.5mm x 263.0mm
- Weight: 8.8kg
Only £279.99 inc VAT.
ORDER NOW
Gibbo - How do the Iiyama ProLite E2607WS 26" compare to the Hanns.G 27.5"?
I'm upgrading from a 22" Belinea mainly for the extra resolution. Are the above monitors fairly similar in quality?
I can't compare it to another monitor, but I have the 26" Iiyama listed above and it's excellent. Only downside is not having 1:1 mapping (unless this is a revised version that does have it now).
I'd definately recommend it. (but do your homework obviously!)
So with it being on this weeks offers makes it a good deal?
I'm also looking at either the Hanns.G or the 26" Iiyama, suppose I should have a google for some reviews of the ProLite E2607WS.
HI there
Iiyama is superior to HannsG in quality.
We view iiyama as a premium manufacturer up there with Samsung. :)
I have same 22 as you and going for same upgrade so i will watch this thread carefully nearly hit the buy on the Hanns.G 27.5 then come across this thread :)
The stand on the 26" isn't exceptional, it's very basic, but it does it's job. The speakers in the monitor aren't too bad either.
(I did get interference noise from the speakers strangely though the HDMI connection I think, not sure why as it was intermittent when the sound wasn't on, and could easily have been my cable or my gfx card. Don't let this put you off!)
Thanks. I'm really struggling to choose between these three. I'd rather like the 16:10 of the 26'', but the fact that it doesn't (apparently) have 1:1 pixel mapping puts me off a bit.
I'm also not sure whether a slightly better stand is worth an extra £20 for the
B2712HDS.
Argh....
By the way - when do the 'This Week Only' offer end?
B2712HDS.
Argh....
Wednesday next week. :)
