Hey im currently thinking of upgrading my PC, after the last PSU and hdd blew its not felt the same, some of my fans arnt working for example (more about that at the bottom)
My current sepcs ( Its over 2 years old now) are:
Graphics: Zotac GeForce GTX+ 9800 2gb
CPU: Intel Core 2 Quad 2.40GHz (Over clocked to 3.02 GHz)
Motherboard: Abit ip35 pro xe
Ram: 4gb Duel channel
HDD: 1x 150g and 1x 300gb - This got replaced by the guy who sorted my pc so know idea if its any good
PSU: Coolmaster M250 (600w) - Also got replaced
I was looking at getting http://www.overclockers.co.uk/showproduct.php?prodid=FS-169-OE&groupid=43&catid=1892&subcat=@ a later date buying the parts seperately and putting it all together
System Specification
- Case: Xigmatek Midgard Midi Tower - Black
- Power Supply: Corsair CX 600W
- CPU: Intel Core i5 760 2.93GHz overclocked to 4.00GHz
- Motherboard: Gigabyte P55-USB3 Intel P55 (Socket 1156) DDR3 Motherboard
- Cooler: Xigmatek Dark Knight CPU Cooler
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
- Hard Drive: Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache
- Graphics Card: Gigabyte GeForce GTX 460 OC 1024MB GDDR5
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
With a blue ray player instead any maybe more Vram
So worth the upgrade or not?
Also problem I mentioned from above, Currently none of the fans on my case work since I got it back from being fixed. I think it may be down to the PSU not being able to handle it since I had a 750w Corsair one. Ive tried enabling the fans in the bios but it restarted made a horrid noise ( fans moving im guessing or something ) which then made it turn of and revert back to old settings again where it turned on fine.
Currently the only fans ive had running since it was fixed was the CPU one, im sure that cant be healthy for it :X
Thanks if you post there
