Hi again all
after the great advice you all gave me on buying my sons graphic card - which he was over the moon with, so thanks again
- i thought i'd pop back and ask for some advice on abit of an upgrade to my own system...
basically, i need your recommendations for a new psu as im going to (attempt to) use two graphic cards now (crossfire?
my cards are : (er... this is what it says on the boxes)
sapphire vapor x toxic hd 4870 1gb gddr5 pci-e dual dvi-i/tvo
xfx radeon hd 4890 1gb gddr5 dual dvi tv pci-e
my system specs are: (these are just copied from the "properties" in "my computer" so please advise if i need to supply any more info)
Intel (r) Core (tm) 2Quad cpu
Q9650 @ 3.00ghz
3.00 ghz, 3.25 ghz ram
at the moment my psu is a 750w rubbish no-make one (win power??)
and im using windows xp 32 bit
my monitor is a 42 inch toshiba - which doubles as a telly and erm... i dunno, do you need any more info?
oh yes, i play games like wow (shush!) the sims 2 and 3 (dont you Dare comment!) Silverfall, The Witcher and fallout
many thanks for any advice you can offer
Q9650 @ 3.00ghz
