Help 16GB usb drve only comes up as 2GB
7 Sep 2008
Hi guys.
I used unetbootin to try to get my sandisk 16GB usb disk to become bootable
it was def 16GB before but now my disk looks like it is 2GB and there is some 12gb that I can't get to
check this out:
I can't seem to delete the 2GB partition either
there is no options for the 12gb it is all greyed out
any suggestions?
Can you not merge the partitions in anyway ?
If not can you not format the drive and then do it again.
Try extending volume L: to the maximum you can, the space is there it has just not been allocated to a partition.
arghh i could use gparted but i dont have linux nemore
plus i cant even begin to remember how to delete a partition using fdisk
i can format in windows cmd
d:/
format
but it'll still only show 2gb
i think i need som1 with linux installed this is annoyin
gparted on a cd is the way to go here.
It's been known for flash memory to be mis-sold, claiming to have a higher capacity than it actually does. I've also had flash memory go faulty in such a way that the available capacity decreased over time.
I was missold flash, and the way to test it is with h2test4_1.4 works for any writeable media, HDD and flash, works by writing data to the disk and verifying. Used it to prove a 16Gb drive was in fact about 800Mb. Got my money back but won't buy large capacity flash there anymore.
