how can un-compressible data degrade the drive?
Somone really needs to sticky a thread with info on the vertex 2. Get one of these threads every time someone buys one and everytime someone has to explain how the sandforce controller works.
so how would i know if it as "boged it down"? is it by the heath status?Because the way Sandforce drives work is that the controller compresses the data written to the drive, this means it has to transfer less data so can report the high speeds it does, the problem is if you bombard the controller with a lot of un-compressible data it bogs it down and it can take days, even weeks to recover, sometimes it won't recover fully depending on the amount of un-compressible data you are bombarding the drive with and you'll have to secure erase the drive to bring the speed back up.
Can't see the number of benchmarks you've run should impact performance.
is there anything i can do?
my read result as been 153mb seen i had the drive 2days ago. i'm sure the write was 135mb~ before i flashed it to 1.24.
i don't want to rma it if it's fixable myself.
this is my first SSD, i was told these are easy to maintain but it seems like they not.
I asked simply because the default is 1GB filesize and 5 runs, which is 5GB of data each time, which if done enough would degrade the drive.
so it hasn't damaged the drive? it just slows it down, right.
the heath status says 100% i guess that is the lifespan.
when u say degraded u mean by performance, not actually damaged the drive? , right.
