New Rig!
28 Nov 2010
Hey all im new to these forums!
Im planning on building a new rig at christmas! :D
just need any advice i can get really, I already have A 1TB HDD, Windows 7, Monitor keyboard etc etc!
Here is what im planning on so far:
Case: Asus Vento TA-M21, Black, Gaming Mid Tower
PSU: 750W Antec TruePower New Modular
Mobo: MSI P55-GD65, Intel P55 Express, S1156, PCI-E 2.0(x16)
Memory: 4GB (2x2GB) Corsair XMS3 DDR3 PC3-12800 (1600)
CPU: Intel i5 760, S1156, Lynnfield Quad Core, 2.8 GHz, 8MB Cache
CPU Cooler: Corsair H50-1 Hydro Series
GPU: 1280MB Gainward GTX 470 GS Good, 40nm, 3400MHz GDDR5, GPU 650MHz, 448 Cores
DVD Drive: LG GH24NS50
Thanks for any advice :)
Thanks all for the replies!
Im getting all the bits before xmas apart from the GPU ive got to wait till xmas day for that! abit annoying but gives me something to look forward to i guess :D
I'm not sure on something here, i bought windows 7 for my laptop, I'm guessing i cant use the same CD key on this system? unless i put my laptop back to vista would that work then?
Also what is the difference between OEM and Retail? Sorry for all the questions :P
Thanks!
Thanks!
OEM is tied to your motherboard ( if your motherboard fails and you buy a new mobo you can call Microsoft to activate it again). Retail is not tied to your mobo and therefor you can install retail on any new computer you buy. If you just have one license then you can only legally use that license on one PC, otherwise it automatically gets transfered when you activate it on the new PC.
As for OEM, it's what computer builder retailers install by default on a pc system, unless the user has requested ( bought ) the retail version.
In regards to your graphics card choice, if your waiting til christmas to buy it, its definitely worth looking to see how much the 570GTX cards actually launch at price wise as they will really squeeze the price of the previous generation of nvidia cards!
