Automator
18 Oct 2002
Manchester
Just wondering what other people use this absolute gem of a utility for?
I use it at work to automate, funnily enough several repetitive tasks,
But I am interested in seeing what other people use it for and hopefully pick up a few tips.
I also use it to automatically move and delete all pdfs (I download probably 100+ a day in the job I do, and manually clearing out the downloads folder got tiring) so now I have an ical event to automtically purge the folder/trash.
What do you tend to download a lot of?
Myself I have my downloads folder automatically file away any webarchives of online receipts.
I download dmgs, zips, movies, audio, pictures, all sorts... Hence Usually every so often I go in and drag the video to my video folders and sort by series etc, drag the music to my music archive, collate all the dmgs, and then I check which ones are old and delete them etc Loads of tedious work, hence my 500G download drive is 77GB free, and I have far to many files to bother sorting anymore, so i'll probably just delete most of it .... :)
this sounds quite neat, but how do you do that, what is your process. I could just make a Receipts folder, and print to pdf any receipts i get and savethem there, but using automater must make it better, but in what way
There's a way of doing this anyway - if you go to print the page, then hit the PDF button, there is an option for 'save to Web Receipts Folder'. It'll make one in your Documents folder :)
Automator is mega useful for loads of bits though.
I have an automator action that creates symbolic links (click here)
Drag the source in to the action, select a destination and bob's your father's brother. No messy Terminal commands :)
I actually used it to re-direct my steam GCF folder on to my NAS, and it works flawlessly.
