1 Dec 2010 at 19:16 #1 jmp_78 jmp_78 Associate Joined 2 Mar 2009 Posts 612 Location Nottingham Mates PC is powering on for few seconds, nothing on screen, then 2 quick BIOS beeps, and power down. Any ideas? He has taken each component out one by one and re-seated, but still same 2 beeps. Thanks
1 Dec 2010 at 19:18 #2 Renni 95 Renni 95 Associate Joined 7 Nov 2010 Posts 383 Location Fleet/ hampshire Reset bios?
1 Dec 2010 at 19:19 #3 jmp_78 jmp_78 Associate OP Joined 2 Mar 2009 Posts 612 Location Nottingham Yeah, my only thought - the clear CMOS jumpers thingy. Will see if anyone else posts, then call him back in 10 with ideas! Cheers
1 Dec 2010 at 19:22 #4 Sgt Tackleberry Sgt Tackleberry Associate Joined 28 Oct 2010 Posts 2,446 Location Colchester I do believe that is the ram, meaning u have 1 or more faulty stick/slot, take one and try each ram and slot.
1 Dec 2010 at 19:22 #5 R088ieS86 R088ieS86 Soldato Joined 25 Oct 2009 Posts 2,724 Location Northampton Id try reseating their RAM (Or trying to boot with one stick is they have more than one)
1 Dec 2010 at 19:24 #6 Sgt Tackleberry Sgt Tackleberry Associate Joined 28 Oct 2010 Posts 2,446 Location Colchester Run memtest86 and see what that says
1 Dec 2010 at 19:25 #7 Thekwango Thekwango Soldato Joined 5 Feb 2009 Posts 17,170 Location N. Ireland it may also be useful to post up his motherboard manufacturer, i believe bios beeps can vary slightly in meaning
1 Dec 2010 at 19:27 #8 gillywibble gillywibble Caporegime Joined 28 Jun 2007 Posts 52,812 Location Tamworth, UK Sgt Tackleberry said: Run memtest86 and see what that says Click to expand... Fail. What mobo?
1 Dec 2010 at 19:28 #9 droyden droyden Associate Joined 4 Oct 2009 Posts 1,007 As above, get the mobo type then check the manual for whether the beeps mean. Should give you something to work on atleast
1 Dec 2010 at 19:28 #10 Sgt Tackleberry Sgt Tackleberry Associate Joined 28 Oct 2010 Posts 2,446 Location Colchester Fail. Only saying as my last system did 2beeps and it was a faulty ram slot. Only saying.
1 Dec 2010 at 19:32 #11 jmp_78 jmp_78 Associate OP Joined 2 Mar 2009 Posts 612 Location Nottingham He has tried each stick of RAM individually, no joy - same 2 beeps.
1 Dec 2010 at 19:42 #12 jmp_78 jmp_78 Associate OP Joined 2 Mar 2009 Posts 612 Location Nottingham Mobo is Asus P5N-E SLI if anyone can shed any further light...
1 Dec 2010 at 19:47 #13 R088ieS86 R088ieS86 Soldato Joined 25 Oct 2009 Posts 2,724 Location Northampton I'd move on to the Graphics card then: reseat / put in another card if he has one to test?
1 Dec 2010 at 19:48 #14 Sgt Tackleberry Sgt Tackleberry Associate Joined 28 Oct 2010 Posts 2,446 Location Colchester Well google is ur friend as it says "2 short beeps: CMOS setting error"
1 Dec 2010 at 20:33 #15 PhoenixUK PhoenixUK Soldato Joined 11 Apr 2008 Posts 3,907 Location Sheffield it's ram.
1 Dec 2010 at 20:51 #16 Crowort Crowort Associate Joined 5 Feb 2010 Posts 1,652 A quick google of that code makes it sound like it is the gfx card. Seems the ram error for that board is it just beeping in a long cycle.
