- 29 Nov 2010
Hi, I'm looking to overclock firstly to 3.0ghz. I haven't tried changing anything yet, as i was hoping someone could just check over bios and help me fill in the blanks.
my specs are:
Processor - q6600 2.4GHZ G0
motherboard - asus p5p43td/usb3
ram - corsair ddr3 1333mhz 2 x2gb
cooler - artic cooling freezer 7 rev 2
TEMPS IDLE 34C/ 35C AFTER RUNNING PRIME95 55C
Here is what i have come up with so far
asus bios:
Ai OVERCLOCKING (MANUAL)
CPU RATIO CONTROL (9.0)
FBS FREQUENCY (333)
PCIE FREQUENCY (100)
DRAM FREQUENCY (DDR3-1333)??? not sure if this possible
DRAM COMMAND RATE (2T)
DRAM TIMING CONTROL (MANUAL)
LATANCY (8 CLOCKS)
TO CASH DELAY (8 CLOCKS)
PRECHARGE (8 CLOCKS)
ACTIVE TIME (24 CLOCKS)
TWR (AUTO)
TRFC (AUTO)
TWTR (AUTO)
TRRD (AUTO)
TRTP (AUTO)
DRAM STATIC READ CONTROL (AUTO)
TRANSACTION BOOSTER (DISABLED)
CLOCK OVER-CHARGING MODE (DISABLED)
CPU spread spectrum (DISABLED)
PCIE spread spectrum (DISABLED)
CPU VOLTAGE (1.350)
CPU VOLTAGE REFERENCE (AUTO)
CPU VOLTAGE DAMPER (ENABLED)
CPU PLL VOLTAGE (AUTO)
DRAM VOLTAGE (1.65V)
FSB TERMINATION VOLTAGE (AUTO)
NORTH BRIDGE VOLTAGE (AUTO)
NORTH BRIDGE VOLTAGE REF (AUTO)
SOUTH BRIDGE VOLTAGE (AUTO)
*ADVANCED*
C1E SUPPORT (DISABLE)
MAX CPUID VALUE LIMIT (DISABLED)
VANDERPOOL TECHNOLOGY (DISABLED)
CPU TM FUNCTION (DISABLED)
EXECUTE DISABLE BIT (ENABLED)
PECI (ENABLED)
INTEL (r) SPEEDSTEP(TM) TECH (ENABLED)
my specs are:
asus bios:
FBS FREQUENCY (333)
LATANCY (8 CLOCKS)
TWR (AUTO)
TRFC (AUTO)
TWTR (AUTO)
TRRD (AUTO)
TRTP (AUTO)
CPU VOLTAGE (1.350)
*ADVANCED*
PECI (ENABLED)
