i7 Overclock Advice
9 May 2004
London
I seem to have gone as far as I can go with my i7 920 D0, rest of my spec is in my sig.
Currenty at 3.8Ghz but temps are getting really high @87C max under prime.
My bios settings are as follows:
Ai Overclock Tuner.....................[Manual]
CPU Ratio Setting......................[21.0]
Intel(r) SpeedStep(tm) Tech............[Disabled]
Xtreme Phase Full Power Mode...........[Enabled]
BCLK Frequency.........................[181]
PCIE Frequency.........................[101]
DRAM Frequency.........................[DDR3-1451MHz]
UCLK Frequency.........................[Auto]
QPI Link Data Rate.....................[Auto]
CPU Voltage Control....................[Manual]
CPU Voltage............................[1.23125]
CPU PLL Voltage........................[Auto]
QPI/DRAM Core Voltage..................[Auto]
IOH Voltage............................[Auto]
IOH PCIE Voltage.......................[Auto]
ICH Voltage............................[Auto]
ICH PCIE Voltage.......................[Auto]
DRAM Bus Voltage.......................[1.65]
DRAM DATA REF Voltage on CHA...........[Auto]
DRAM CTRL REF Voltage on CHA...........[Auto]
DRAM DATA REF Voltage on CHB...........[Auto]
DRAM CTRL REF Voltage on CHB...........[Auto]
DRAM DATA REF Voltage on CHC...........[Auto]
DRAM CTRL REF Voltage on CHC...........[Auto]
Load-Line Calibration..................[Enabled]
CPU Differential Amplitude.............[Auto]
CPU Clock Skew.........................[Auto]
CPU Spread Spectrum....................[Disabled]
IOH Clock Skew.........................[Auto]
PCIE Spread Spectrum...................[Disabled]
C1E Support............................[Disabled]
Hardware Prefetcher....................[Enabled]
Adjacent Cache Line Prefetch...........[Enabled]
Intel(r) Virtualization Tech...........[Disabled]
CPU TM Function........................[Enabled]
Execute Disable Bit....................[Enabled]
Intel(r) HT Technology.................[Enabled]
Active Processor Cores.................[All]
A20M...................................[Disabled]
Intel(r) C-STATE Tech..................[Disabled]
Any advice on lowering these temps/increasing the overclock would be most welcome.
Thanks in advance.
Try dropping you "CPU Ratio Setting......................[21.0]" to 20.0 and try upping your BCLK Frequency 3-5 at a time, run prime95 for 30mins if it's not stable then try upping the voltage a little a time n try prime95 til it's stable then up the BCLK Frequency and so on.
Wow those temps match mine but you have HyperThreading disabled...looks like you might need to re-seat your cooler. Also, enable SpeedStep and set multiplier to Auto (your max speed will still be 3.8 GHz).
Iv found a 20 to be much more unstable then 21. End up getting BSOD @3.8ghz.
Sorry that was a mistake, I do have HT enabled. I will try enabling speedstep and auto multiplier.
Well I reseated my cooler which didnt really make much difference.
1.225v is as low as iv managed to keep 3.8ghz stable. Are these temps too high?
Oh sorry, my mistake, I thought that you wanted to go higher than 3.8 :o
What are your room temps, ambient case temps, and temps on stock? What program are you using to read temps?
Well i would like to go higher but I dont fancy any higher temps then what I have now.
Room temp isnt all that warm, dont have a thermometer to test it though. Same with the case temp.
There is a decent airflow in the case, 3 inlet fans and 3 exhast. Taking the side panel off the case only reduces the cpu temp by a couple of degrees.
Im using Core Temp.
hmm, the fact that taking the side panel off reduces temps may indicate that cirulation isn't that great. In my setup and in a few setups I've seen, temps increase when side panel is removed.
