Hi all,
I have a small, 2 bed, semi-detached house.
Brief run down of the heating:
Downstairs Rad's: Kitchen and Lounge.
Upstairs Rads: 1 in each bedroom and 1 in the bathroom.
The room thermostat is in the hall way at the bottom of the stairs.
The problem is that there is no radiator in the hall or on the landing. The hall is always quite cold so we tend to keep internal doors shut.
Therefore, the room thermostat doesn't really do it's job.
The thermostat is surface mounted so I was considering taking it off the wall, drilling through the wall and mounting on the other side, which is the lounge.
Is this advisable?
I guess the kitchen is a bad idea as when cooking it'll give a false reading.
Also, the thermostat is a mechanical type, made by Siemens. It seems to have quite a large "dead" zone. In that the dial will move a few degrees between on and off clicks. Is this a trait of mechanical thermostats? Should I just buy a new digital one and mount in the lounge?
The thermostat is just that, the timer controls are on another module next to the hot water tank.
Thanks for any advice.
Is this advisable?
