- 17 Sep 2006
- Gloucestershire
Wedding photographers - I know there's some talented guys on here so I wouldnt mind a bit of advice about lighting. Im due to shoot a wedding in Summer, a long time off yet I know but still.....
I've noticed a lot of wedding photographers use a remote flash that they leave in the corner/side of the room. So we're mainly talking about lighting the after party event rather than the wedding itself.
For example:
Now I assume you have to use an 'on-camera' flash too, to fill in the dubject, otherwise the subjects would almost be silhouettes (to a certain extent).
So, I need to refer to an amazing drawing I just whipped together thanks to my new Intuos4 tablet (awesome bit of kit btw!)
All of the photos above is when the photographer is at A on the diagram above, or very close to.
So here they are using the flash to give a nice outline to the people, this effect I really like! And I guess they have a flash on the camera, maybe bouncing it off the ceiling so it's a really soft light.
But....if the photographer moves to position B, I assume he turns one of the flashes off, depending on how far the remote flash is away from the people, as you wouldnt want both flashes lighting the same thing.
Do any of you guys do this? Or have any advice for doing this?
Also, if you have a flash on the camera, and a remote one, how do you control them both? As the hotshoe on the camera is taken up by a flash, so how would you trigger the remote flash?
All and any help would be great
For example:
