Hi All,
I need some advise if any one fancies helping.
I need to purchase a very high spec machine with Windows XP 64-bit Pro.
Windows 7 is not an option as a critical application is only supported on XP, and manufacturer support is required. Manufacturer does not support virtualised XP.
The machine must also support 4 monitors (not HDMI), it is not being used for 3D graphics but I don't want the 4 monitor requirement to slow the display.
Anyone any ideas on spec? I'm asking as the complication of 64-bit XP means I need to be sure the spec will run under that OS
Thanks
Thanks
irectX 11
