- 25 Mar 2004
- Fareham
Hi guys,
I'm trying to run a query to determine how much data a group of users has in our Zantaz EAS system, the problem is the query is taking a bloody long time to process, so I think it could use some optimisation. The databases are very large.
How can this be sped up?
This is what I currently have:
I've added my query designer view so you can better see how this is working, essentially I'm joining tables based on common fields.
http://img94.imageshack.us/img94/7842/easquery.jpg
So this works with 4 databases:
GROUPS
USERS
REFER
PROFILELOCATION
GROUPS contains all the groups with GROUPID/GROUPNAME.
USERS contains the list of users, each user has a GROUPID which can be linked to the GROUPS database to figure out which group a user belongs to. This database also lists the USERNAME and EASSTATUS values. If EASSTATUS = 0 then the user is enabled, 1 is disabled.
REFER lists messages that belong to users
PROFILELOCATION lists all the messages with compressed and uncompressed sizes
Cheers
Code:
SELECT USERS.USERNAME, USERS.USERID, USERS.EASSTATUS, SUM(PROFILELOCATION.COMPRESSEDSIZE) As COMPRESSED_SIZE,
SUM(PROFILELOCATION.UNCOMPRESSEDSIZE) As UNCOMPRESSED_SIZE
FROM GROUPS INNER JOIN
USERS ON GROUPS.GROUPID = USERS.GROUPID INNER JOIN
REFER ON USERS.USERID = REFER.USERID INNER JOIN
PROFILELOCATION ON REFER.MSGID = PROFILELOCATION.MSGID
WHERE GROUPS.GROUPID = 191 and REFER.FOLDERID > 0
GROUP BY USERS.USERNAME, USERS.USERID, USERS.EASSTATUS
ORDER BY USERS.USERNAME
GROUPS
USERS
REFER
PROFILELOCATION
Cheers
