Wait...you get a forum setup to help customers and get posts about issues?
Well I never.
The only network issues that I can see are the spikes in utilisation that have previously been referred to in this thread. We are only allowed to escalate these issues to networks once the utilisation has reached a certain level in terms of how high the utilisation is and the length of time it stays above that level. At this point the utilisation on your local chassis does not break these thresholds so we are not in a position to escalate. We will continue to monitor your local chassis and if the situation changes we will deal with as appropriate.
Regards,
Ray Miranda
Help & Support Forum Team
.Saturated UBR during peak time.
There's your problem. Phone up and complain.
The way some ISP's go about traffic shaping should not be allowed, to cut something like a 20Mb or 50Mb connection to less than 10% is just not acceptable, if they must do it then there should be a reasonable minimum of no less than half of what you're paying for even then i don't think traffic shaping is right.
