FCP works fine on my 13" Macbook Pro?
Works better on my Mac Pro though I'll give you that hehe![]()
I guess I was mistaken then, I was just relaying what I was told in the store.
Eh?
I can run Final Cut Pro just fine on my 13' inch MacBook Pro![]()
I'm buying a firewire 800 ext hard drive (1-2TB) for the iMac. Two questions! .
1. When you use a ext hard drive for Time Machine, can you use it for just normal storage as well?
2. Is firewire 800 fast enough to be used as a primary source for editing HD video. I.E, is my footage best stored on the ext or int hard drive?
Special thanks to Brian8bit.
For a 7D it's perfectly fine.
It's only 5.5Mb/sec.
