5 Dec 2010 at 16:31 #1 aquabat aquabat Associate Joined 3 Dec 2010 Posts 137 Hi, A newbie question i'm sure but i have a q6600 at 2.4 and was wondering how i find out what motherboard it is on? Thanks Paul
5 Dec 2010 at 16:32 #2 axer axer Soldato Joined 25 Mar 2004 Posts 2,885 Location Iwade, Kent Download CPU-Z and flick to the relevant tab for the info! EDIT: Which is 'Mainboard'
5 Dec 2010 at 16:33 #3 cmndr_andi cmndr_andi Soldato Joined 23 Apr 2009 Posts 11,973 Location Cheshire You best bet is to download and run CPU-Z and see what it says in the mainboard tab. Also, if your PC is a pre-build (from a company) then if you know the model name of the PC, you can usually find out what motherboard is used.
5 Dec 2010 at 17:10 #4 aquabat aquabat Associate OP Joined 3 Dec 2010 Posts 137 Thanks for the help, I will run CPU-Z and find out. It was a "Competitor* special!! Acer all the way.... ) Thanks Paul
5 Dec 2010 at 19:58 #5 PhillyDee PhillyDee Soldato Joined 12 Feb 2007 Posts 14,117 Location South Shields aquabat said: Thanks for the help, I will run CPU-Z and find out. It was a **** special!! Acer all the way.... ) Thanks Paul Click to expand... Delete the bit ive starred out, and then read the FAQ! No competitors in here, if its not from OcUK, then dont mention it
