Thermostatic heating controls
29 Sep 2003
Newcastle upon Tyne
Hi all
I'm just thinking about how I have my heating set and whether it is the most economical way to run it. We have a wireless thermostat located in the sitting room and this is set to reach certain temperatures at different times of day; so in the morning and evenings it's set to reach 21ºC and at other times it's set to reach 15ºC. The radiator in the sitting room does not have a thermostatic valve, but the normal valve is open as far as it can go.
From there I am using the thermostatic valves in the other rooms (kitchen and 2 bedrooms) to reach the desired temperature for each room individually. The bathroom radiator is just a normal valve and is open to maximum as towels hang on the radiator.
Is there anything I can do different to make this setup more efficient?
Many thanks
Michael.
As far as your settings go it appears to be bang on. Radiator without thermostatic should be in the biggest room along with the main thermostat. Other radiators valves set to suit.
