** Diamonds are a girls best friend **
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Guys,
We have received our first delivery of the IC Diamond Thermal Compund. As the main material is diamond, this compound has a better heat conductivity than metal compounds, it should out perform any other compounds available.
To celebrate we are going to give away 25 units of the IC Diamond 24 Carat, and 25 units of the IC Perihelion for you to use/test/post your findings on our forums. To obtain a free sample post a reply in this thread "Diamonds are a girls best friend" and which compound you would like. The first 25 replies for each will get a free copy. Your forum account must be linked to your shop account so I can obtain your details for posting the free units out. You will also have to post on the forum advising your opinion and thoughts on this compound.
IC Diamond 24-Carat Thermal Compound (4.8g) @ £14.99 inc VAT
IC Diamond out performs all other compounds in independent user testing amoung the popular brands tested, IC Diamond contains 92% pure syntheic Diamond. Purified synthetic diamond has a thermal conductivity of 2,000-2,500 W/mKL compared to 406-429 W/mK for pure silver. IC Diamond is electrically none-conductive and none-capacitive providing protection for electrical components when used.
IC Diamonds exceptional durability is due to its high bulk loading of micronized diamond particles. Each tube of IC Diamond contains over 92% micronized diamond and ais 94% fully loaded counting other miscellaneous particles. This highly loaded mix (90% + Bulk loading) is recommended by chip manufacturers to limit pump out due to thermal cycling.
IC Diamond is a stand out amonst all compounds by providing both high performance and long term reliability. Lightly loaded or creme type pastes initially provide some preformance, however the effect can be transitory, sometimes only lasterin a couple of weeks or months. You are safe in the knowledge that IC Diamond thermal conductivity lasts forever.
Based on Independent tests IC Diamond performs 2.77°C better than OCZ Freeze, 3.28°C better than Arctic Cooling MX-3, 3.38°C better than Arctic Silver 5 and 4.74°C better than the Intel generic paste.
- Each tube of IC Diamond Thermal grease contains 7 carats of micronized diamond with diamond particle loadings @ 94% by weight. Material loading above 90% is recommended as the best combination of rheological and thermal properties to minimize interface pump out due to thermal cycling.
- Superior bulk conductivity
- Excellent thermal impedance
- Tight particle distributions
- < 40 µ maximum particle diameter
- Silicone free
- Lower viscosity
- Greater stability
- Non capacitive or electrically conductive
Only £14.99 inc VAT.
ORDER NOW
IC Diamond 7-Carat Thermal Compound (1.5g) @ £6.99 inc VAT
- Silicone free
- Lower viscosity
- Greater stability
Only £6.99 inc VAT.
ORDER NOW
IC Diamond Periphelion Ceramic Thermal Compound - (4g) @ £6.99 inc VAT
IC Perihelion is made for mid range performance geared towards the user on a budget. The ceramic based compound is suitable for all applications from a CPU Air Cooler right through to Watercooling applications and easily beats the performance of similar priced compounds. Each syringe contains 4grams of compound, enough for quite a few applications.
Only £6.99 inc VAT.
ORDER NOW
24-carat if possible please :)
Finally a chance to try something different than AS5! :) Will post results of the differences!
IC Diamond 24-Carat Thermal Compund (4.8g)
Please :)
Will conduct a detailed review, pitting it against my Liquid Metal stuff :)
IC Diamond 24-Carat Thermal Compound as well please :)
My test will be against: Arctic Silver 5
Pleaseeeee. :)
Everyone wants the Diamond24. No takers for the Ceramic?
Everyone wants the most pricey 1 to test probably because it'll yield the best results, I'm sure when they run out there won't be any refusal of people wanting to test the ceramic one also :p
24-carat for me too :D
Edit: And as said above, why would people pick the one that gives 'mid range' performance over the one that out-performs all the others? :p
Given the quantities, the 24 carat is actually cheaper than the 7 carat!
