How do I put videos on to iPhone?
  • Thread starter Thread starter TS7
  • Start date Start date
TS7
TS7
16 Feb 2010
East Mids
Whenever I select 'add file' to library and then click on the episode of 'Friends' I want to put on and click ok, nothing happens! It's fine when I transfer music onto iTunes, just doesn't work with video.
Any help?
Select your phone on the sidebar in iTunes, then in the right hand side of the window select Movies from the top headings, and tick the video you require on your phone. Sync
But I can't get the video onto iTunes. How do I do that?
Thanks
Miro is the most painless drag and drop solution. Also adds to iTunes.
Install Miro converter. Run. Choose device, drag file in, tick add to iTunes, click convert. Win.
Handbrake is good but it is overkill.
