[BUILD] Final check.
19 Nov 2010
London
Im ordering this tonight, double checking if this will all fit and run smoothly, I will be adding a graphics card to this system for £150, A suggestion on that card (exact model and manufacturer would be appreciated) Thanks a bunch.
Coolermaster Elite 430 All Black With Elite 500W PSU
Seagate ST9500420AS 500GB 2.5" Hard Drive SATAII 7200rpm 16MB Cache - OEM
Corsair 4GB (2x2GB) DDR3 1600MHz/PC3-12800 XMS3 i5 Memory Kit CL9(9-9-9-24) 1.65V
MSI 870-C45 AMD 870 Socket AM3 GB LAN 8 Channel Audio ATX Motherboard
AMD Athlon II X4 640 Socket AM3 3GHz 2MB L2 Cache Proccessor
LiteOn IHAS124-19 24x DVD±RW DL & RAM SATA Optical Drive - OEM Black
I would suggest for around £150 a Nvidia GTX 460. Not to sure on particular models but the card itself is very good.
Can i ask why you have chosen a 2.5 hard drive which is made for laptops? it will work but just strange :p
Edit: Damn stulid your too fast lol
A miss click i assume didn't check that. Can you sugest me another.
