*****THIS WEEK ONLY 08/12/2010 - Huge Christmas Monitor Sale & Much More!*****
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
For the run upto Christmas we have decided to have a very special and large This Week ONLY full of many great deals, particular monitors with incredible savings:-
BenQ G922HDAL 18.5" Widescreen LED Monitor - Black @ £79.89 inc VAT
The BenQ G922HDAL is built to broaden your view with 18.5“W 16:9 LCD display! The best part is it’s also energy efficient, reducing power consumption by 23.3% in comparing to previous model.
5ms response time means that even highly dynamic video is rendered fluidly without ghosting or other artifacts.
With a dynamic contrast ratio of 40000:1 to give you splendid image details and clarity in darkened and complex motion pictures, everything becomes more vivid!
BenQ’s exclusive Senseye®+Photo Technology gives you preset modes—Standard, Dynamic, Movie, Photo—that provide instant optimized settings for different usage scenarios. Senseye®+Photo is an enhanced version that adds support for the industry-standard sRGB color space, allowing you to obtain consistent results when you view and manipulate images on the G922HDAL and on other sRGB-compliant devices.
This mode allows aspect ratio’s other 16:9 to be displayed without geometric distortion. So, it can perfectly display a full picture with its 16:9 widescreen panel – allowing you to enjoy the best visual entertainment.
Features
- Screen Size: 18.5" Wide
- Resolution (max.): 1366 x 768
- Pixel Pitch: 0.3 mm
- Brightness: 250 cd/m²
- Contrast Ratio: 1000:1
- Dynamic Contrast Ratio: 5000,000:1
- Response Time: (tr/tf) 5ms
- Display Area: 409.8 x 230.4 mm
- Display Color: 16.7 million
- Viewing Angle: (L/R;U/D) (CR>=10) 90 / 65
- Terminals: D-sub
- Horizontal Frequency (Max) KHz 30 ~ 83
- Vertical Frequency (Max)Hz 50 ~ 76
- Video Bandwidth (MHz) 110
- Colour Temperature Reddish / Normal / Bluish / User mode
- Power Consumption 23W (on mode)
- Auto Switching Power Supply Built-in
- Power Saving Mode <1W
- Senseye+Photo Technology
- HDCP Support: NO
- Adjustments Tilt: -5 / 20 (down / up)
- Dimensions (HxWxD): 345.8 x 444.4 x 165 mm
- with wall mount: 278.8 x 444.4 x 62.1 mm
- Weight: Net 2.8 kg / Gross 4.3 kg
- Accessories (Standard): VGA cable / Power cable
- Warranty: 2yrs
Was £84.99 Inc. VAT
Only £79.89 inc VAT.
ORDER NOW
OcUK Cream 18.5" Widescreen LCD Monitor - Glossy Black @ £76.36 inc VAT
This OcUK Value 18.5" monitor has an industry leading ultra-fast 2ms response time making it perfect for blur-free video and gaming. With it's 2000:1 contrast ratio and digital connectivity there is no other LCD that can match the combination of value and performance.
- Screen Size: 18.5" Widescreen
- Resolution: 1360x768
- Contrast Ratio: 2000:1
- Brightness: 250cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- Dimensions: 444.0mm x 324.0mm x 170.5mm
- Weight: 3.2kg
- Warranty: 3 Years On-Site
Was £79.99 Inc. VAT
Only £76.36 inc VAT.
ORDER NOW
Nvidia GeForce 3D Vision Kit @ £117.49 inc VAT
Upgrade your PC to a fully immersive stereoscopic 3D experience with Nvidia GeForce 3D Vision. A combination of high-tech wireless glasses and advanced software, GeForce 3D Vision automatically transforms hundreds of PC games into full stereoscopic 3D. Just slip on the stylish glasses and pair them with an Nvidia GeForce GPU and a "GeForce 3D Vision-Ready" display to experience characters and environments come to life on the screen. In addition, you can watch 3D movies and 3D digital photographs in eye popping, crystal-clear quality. Give your eyes something to talk about with GeForce 3D Vision. Requires 120Hz Monitor.
- Convert standard games into stereoscopic 3D
- Highest quality stereoscopic 3D solution
- Designed for comfort and style
- Wear over your prescription glasses
- High power wireless infrared communication
- Game for more than forty hours on a single charge
- Adjust 3D depth adjustment from the IR emitter
- Watch movies in 3D
- Stereoscopic 3D picture support
NOTE: Requires 120Hz Monitor
NOTE: Requires Nvidia GeForce 8800 GTX or above Graphics Card
Was £119.99 Inc. VAT
Only £117.49 inc VAT.
ORDER NOW
BenQ G2222HDL 21.5" Widescreen LED Monitor - Black @ £111.61 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2222HDL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Response Time: 5ms
- VESA Compliant
- Dimensions: 504.6mm x 392.9mm x 175.0mm
- Weight: 3.8kg
- Warranty: 2 Years On-Site
Only £111.61 inc VAT.
ORDER NOW
LG W2246S-BF 22" Widescreen LCD Monitor - Glossy Black @ £99.99 inc VAT
Gamers and movie buffs will love this widescreen LCD monitor. LG’s FLATRON f-ENGINE picture-enhancing chip offers enhanced image definition, smooth motion, and superb colour reproduction, making it ideal for watching films. And, with a 5ms response time, your video games will look better than ever.
- Resolution: 1920 x 1080
- Connection: D-Sub
- Viewing Angle: 170/160 degrees
Was £117.49 Inc. VAT
Only £99.99 inc VAT.
ORDER NOW
OcUK Cream 22" Widescreen LCD Monitor - Black @ £99.99 inc VAT
The OcUK Cream 22" monitor has an industry leading ultra-fast 2ms response time making it perfect for blur-free video and gaming. With it's 2000:1 contrast ratio and digital connectivity there is no other LCD that can match the combination of value and performance.
Features
- Screen Size: 21.6" Widescreen
- Contrast Ratio: 5000:1
- Brightness: 300cd/m²
- Multimedia Speakers
- Warranty: 3 Years On-Site - Call 0870-2485492 to arrange on-site swap out (8am-4pm)
Was £104.99 Inc. VAT
ORDER NOW
Samsung SM2233RZ 22" 120Hz 3D Widescreen LCD Monitor - Black @ £187.99 inc VAT
The Samsung 2233RZ monitor boasts the refined, streamlined and unique design, in addition to its top-class performance, that consumers have come to expect from Samsung. The display is housed in a thin, glossy black bezel that is a stylish accent to any environment and provides a compelling 3D experience with incredible picture quality. Unlike many other widescreen monitors, the Samsung 2233RZ displays 5:4 and 4:3 images at accurate aspect ratios without enlargement or distortion.
- Resolution: 1680x1050
- Contrast Ratio: 20000:1
- Response Time: 5ms (2D) / 3ms (3D)
- Inputs: 1x DVI-D
- VESA Compliant
- Dimensions: 516.8mm x 421.3mm x 208.7mm
- Weight: 5.5kg
- Note 3D Glasses not included, purchase these seperately from ALSO purchase.
Was £199.98 Inc. VAT
Only £187.99 inc VAT.
ORDER NOW
LG Flatron W2361V-PF 23" Widescreen LCD Monitor - Black @ £158.61 inc VAT
Gamers and movie buffs will love this widescreen LCD monitor. LG’s FLATRON f-ENGINE picture-enhancing chip offers enhanced image definition, smooth motion, and superb colour reproduction, making it ideal for watching films. And, with a 2ms response time, your video games will look better than ever. A single, all-digital cable input makes it easy to connect and integrate all your digital systems, including cable/satellite boxes and games.
- Screen Size: 23" Widescreen
- Contrast Ratio: 50000:1
- Inputs: 1x Analogue & 1x DVI-D & 1x HDMI
- Dimensions: 519.0mm x 387.0mm x 193.0mm
- Weight: 4.2kg
Was £164.49 Inc. VAT
Only £158.61 inc VAT.
ORDER NOW
BenQ G2420HDBL 24" Widescreen LED Monitor - Black @ £158.61 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2420HDBL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 24" Widescreen
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 4.4kg
Was £170.36 Inc. VAT
ORDER NOW
Samsung P2450H 24" Widescreen LCD Monitor - Glossy Black @ £166.84 inc VAT
Film fans and gamers will love the Samsung SyncMaster P2450H TFT display! The Samsung P2450H is a 24 widescreen monitor that willplunge you into all your favourite films and 3D games with breathtakingly realisticresults. The P2450H has a fantastic contrastratio for deep blacks and rich colours. Plus, the P2450H has aresponse time of just 2 ms which is great for online games! Plus, the Samsung SyncMaster 2450H has a wide selectionof connections, including an HDMI port for hooking up a HD games console orcamcorder.
- Contrast Ratio: 70000:1
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 578.0mm x 430.0mm x 190.0mm
- Weight: 5.4kg
Was £179.99 Inc. VAT
Only £166.84 inc VAT.
ORDER NOW
Hanns.G HZ281HPB 27.5" Widescreen LCD Monitor - Black @ £234.99 inc VAT
The Hanns.G 27.5" has an industry ultra-fast 3ms response time making it perfect for blur-free video and gaming. With it's 15000:1 contrast ratio and excellent viewing angles there is no other TFT that can match the combination of quality, value and performance. Making the large screen affordable to all this 27.5" is ideal for gamers and home cinema use due to its huge size and 1920x1200 resolution.
- Screen Size: 27.5" Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 15000:1
- Brightness: 400cd/m²
- Response Time: 3ms
- VESA Compliant
- Dimensions: 653.0mm x 523.0mm x 254.0mm
- Weight: 8.5kg
Was £259.99 Inc. VAT
Only £234.99 inc VAT.
ORDER NOW
Hazro Ultra-Sharp HZ30Wi 30" Widescreen LCD Monitor - Black @ £762.58 inc VAT
The Hazro HZ30Wi is ideal for graphics and visual media, where professional grade technology meets revolutionary design. The massive 4MP (2560x1600) WQXGA resolution brings a new dimension to on-screen graphics. For the performance-driven individual, the Hazro HZ30Wi provides the ideal navigation perspective for your desktop in the home or office environment.
S-IPS display technology delivers unsurpassed levels of colour saturation. It results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. The 30" monitor is available as the HZ30Wi or the HZ30Wi-Q. The HZ30Wi features a colour gamut of 92% NTSC which almost covers the complete AdobeRGB spectrum and encompasses the sRGB workspace entirely. When applied in colour critical applications the result is clear brilliance.
Wherever you need it most, the Hazro HZ30Wi performs with consistency and clarity to optimise your visual experience. The Hazro HZ30Wi recognises groundbreaking technology without compromising efficiency, whilst tailoring to the needs of the discerning, professional, user. The masterful design outside augments the genius within, with the Hazro HZ30Wi collating top industry-spec innovation with rock-solid dependability to perform when you need it most, time and time again.
With the Hazro HZ30Wi, you can view perfectly rendered images without compromising on the space you need to take your creation from conception to fruition. View an uncompromisingly crisp, and sharp, output that won't strain your eyes in a resolution and pixel pitch that'll inject life into your work with piercing detail.
The Hazro HZ30Wi offers three times the workspace of a standard 19” monitor and 77% more workspace than a 24" [16:9] display - allowing creative freedom and practicality. With quicker access to colour tools, palettes and document windows, the HZ30Wi is proven to increase efficiency and output. Anyone can see the tangible results of being able to view two application windows side-by-side. Whether it's to look at a website and its code simultaneously, or if it's to streamline data-entry processes, the final result will still be improved efficiency – and, in the case of businesses, an impact on their bottom line.
The built-in 4 port mains-powered USB hub allows for quick connection to peripherals such as external HDDs and keyboards etc. Each USB port will draw a maximum current of 500mA which allows for even the most power hungry USB devices to be connected without the need for external DC adapters.
Specification:-
- 30" Widescreen
- About 52.5% more screen area than a true 24" Panel with 1920x1200 resolution.
- The only 4 mega pixels monitor that shows true resolution of mega pixel pixel photos
- Higher definition than HD Television to meet the most stringent video needs
- 2560 x 1600 (WQXGA) Optimum Resolution (Dual Link capable DVI-D graphics card required)
- 16.7 Million Colours
- 1000:1 Contrast Ratio
- 8ms Response Time (8ms Grey-TO-Grey)
- 300 cd/m2 Brightness
- One DVI-D Input with HDCP support
- Height adjustable stand
- Kensington security port
- VESA mounting compatible
- Integrated powered USB 2.0 hub: 4 downstream / 1 upstream ports
- Supplied with a Dual Link DVI Cable
- Warranty : 3 year return to base warranty
Was £799.99 Inc. VAT
Only £762.58 inc VAT.
ORDER NOW
Iiyama ProLite E2607WS 26" Widescreen LCD Monitor - Black @ £246.74 inc VAT
The new flagship product from Iiyama is the E2607WS, a High Definition, 2ms 26” LCD solution perfect for today’s demanding applications. Superb colour quality is achieved by a 4000:1 Advanced Contrast Ratio. The OptiColour features allows quick and simple adjustment of the colour settings to suit the application or mood. 5 Watt speakers offer Stereo Audio performance well above the average multimedia display available today. The three input configuration of HDMI, DVI and Analogue guarantees compatibility with the flexibility to switch between multiple sources.
- Screen Size: 26" Widescreen
- Contrast Ratio: 4000:1
- Viewing Angles (H/V): 170°/150°
- Dimensions: 597.5mm x 460.5mm x 238.0mm
- Weight: 8.3kg
Was £269.99 Inc. VAT
Only £246.74 inc VAT.
ORDER NOW
Iiyama ProLite E2710HDS 27" Widescreen LCD Monitor - Black @ £234.99 inc VAT
The Prolite E2710HDS 27” LCD Display features a stunning 2ms Response Time and a High Definition 1920x 1080 Resolution. The 20000:1 Advanced Contrast Ratio and 400cd/m² brightness offer the user clear and vivid images, and the DVI, D-Sub and USB connections ensure compatibility across a range of devices including games consoles and work stations.
- Screen Size: 27" Widescreen
- VESA Compliant
- Dimensions: 642.0mm x 438.5mm x 210.0mm
- Weight: 6.9kg
Was £249.99 Inc. VAT
ORDER NOW
Dell Inspiron 1011 Intel Atom N270 1.60GHz 10.1" LED, Mini Netbook with Bluetooth (Obsidian Black) - Windows 7 @ £211.49 inc VAT
Timing is everything, and now you can have all the time in the world. The newly designed Inspiron Mini 10 offers up to 8.5 hours of battery life to keep you on the go. This Dell Inspiron Mini Netbook features a 160GB hard drive, plenty of room to store all your photos and music. It also features a webcam so you can communicate with friends or family from miles away, or use it to take images of yourself to upload on to the net. If you're looking for a small, lightweight, great quality Netbook for general web browsing, emailing and keeping your photos safe then the popular Dell Mini Inspiron Netbook is for you!
- Intel Atom N270 1.60GHz Pineview Processor
- Display: Built-in 10.1" WSVGA TrueLife widescreen display (1024 x 600)
- 1GB RAM
- 160GB Hard Drive
- 3 in 1 Card Reader
- 3 Cell Battery
- 3x USB2.0
- Bluetooth Connectivity
- Windows 7 Starter
- 12 Months Warranty
Was £224.99 Inc. VAT
Only £211.49 inc VAT.
ORDER NOW
MSI X340 Ultra Thin 13.3" WLED TFT, Intel SU4100, 2GB RAM, 320GB HDD Windows 7 Home Premium - White @ £375.99 inc VAT
The X340 has ingeniously applied fashionable curves in its design which successfully abandoned the cold and lifeless vibe of the traditional notebook computers. The material is gentler to the touch compared the metal, and the paint finish is glazed and UV processed, added with the perfect ratio as a total package, creating the most simplistic yet modern styling, fitting for the most contemporary trend anywhere. With all these unique features, it proves that the X340 is not only a fashionable and appealing notebook computer; it also set very high marks for the entire industry. These great reasons are why the X340 should be highly recommended to all of the contemporary metropolitans anywhere. The X340 has selected the 13 LCD display as oppose to the 12” or even smaller sizes. This provides much more comfort in reading and operation as well as less weight restraints compared to the 14 models. The 16:9 theater ratio can provide bigger visual area. When watching movies, the black bars on the top and bottom of the 16:10 aspect ratio screen can also be avoided. This is perfect for playing HD videos at any possible angle, absolutely ideal for visual enjoyment. The X340 is embedded with the LED power-saving backlight technology in providing better colour fullness and brightness, elevating the total quality of imagery. Furthermore, the lower usage of power can offer a longer operating time. The Vivid Technology can enhance the richness in colours from the source of the signal so the images displayed can provide more levels and details. This also gives a more three-dimensional expression during gaming, watching movies or viewing pictures, and even during the editing process. X340 is also equipped with the exclusive ECO Engine power management system, so you can select freely from the five different modes suitable at your convenience. The five modes include office, gaming, movies, presentation, and turbo battery. Through varies conditions such as the brightness of the screen and standby timeframe, the power consumption can be much more flexible, providing more hours of operating time. This escalates the productivity of the X340 as well as convenience for our users.
The X340 features the latest Intel Centrino Processor Technology, which uses Intel Core2 Solo ULV Processor and Intel GS45 + ICH9M-SFF Chipset, to deliver long battery life, innovative mobile solutions with unrivaled processor performance, stunning new HD capabilities, and great wireless connectivity (Integrated WiFi+ optional WiMAX, up to 450mbps 802.11 b/g/n). HDMI Digital Terminal Interface offers more than 5 GB of transmitting bandwidth; it also lessens the complications of cables. The X340 offers the very best in image quality through the HDMI Terminal so it may have the most realistic picture perfection. The X340 is embedded with a high pixel webcam incorporated with the design of the notebook for a slick and technological appearance. The user may broadcast live during teleconferencing, capturing and recording every exciting moment. Great quality and richness in colours when taking photos both indoors and out adding even more excitement. The X340 is also embedded with the IEEE 802.16e WiMAX(Worldwide Interoperability for Microwave Access)wireless module, which highly elevated the variety of wireless internet service, allowing the online experience to be faster and more mobile. Regardless if you’re in the coffee, shops, school campuses, offices, or airports, you may access the world through WiMAX, never missing the latest information. Other than the WiMAX feature, the X340 also processes the 802.11b /g/n Wi-Fi wireless internet access, so you can have all the internet functions fulfilling a mobile lifestyle. The X340 also provides Bluetooth capability which can be connected to cellular phones, earphones, PDA, and other gadgets, say goodbye to the fuss of lines and cables forever. The X340 has provided a complete entertainment interface which includes a 2 in 1 card reader (supports SD/MMC), varies mainstream memory sticks, making it easy inputting data into the notebook computer. Also applicable to many digital products such as digital video and photo cameras, MP3 Players and others, which can all be connected to the X340 Pro through USB 2.0 port. External DVD Burner is also available (optional) so you can play DVD movies or burn important documents
Features:-
- Intel SU4100 1.30GHz Processor
- 2GB of Memory
- 320GB HDD
- 13.3” 16:9 Wide Screen Display (1366*768)
- The Very Best Expression of Slim Aesthetic
- Intel GMA 4500MHD Graphics
- MSI Exclusive EDS (Ergonomic De-Stress) Keyboard
- Advanced Power Saving Technology
- Theater Class 4 Speakers Qualified by Latest Dolby® Surround
- HDMI (High-Definition Multimedia Interface) Output
- Built-In High Resolution Mega Pixels Webcam
- 802.11b / g / n Wireless Lan with Bluetooth (optional)
- 4 Cell Battery (upto 8hr battery life)
- 2 years Warranty
Was £399.99 Inc. VAT
Only £375.99 inc VAT.
ORDER NOW
MSI X600 Ultra Thin 15.6" WLED TFT, Intel SU4100, 4GB RAM, 500GB HDD Windows 7 Home Premium - Black @ £446.49 inc VAT
MSI has launched a new laptop to meet the ever-increasing demands of our mobile needs. The unveiling of its brand new line of ultrathin notebooks is a milestone both technologically and aesthetically. This innovativly-thin laptop has completely revolutionized the idea of a portable computer; its sleek yet simplistic lines fit seamlessly into its polished exterior, raising the bar for thin-notebook design a step higher.
The design of the X600 strives to be literally, as light as a feather, and, as thin as one too. Its near weightlessness and ultra thin exterior has fused graceful design and trendsetting style. Perhaps the most stunning aspect of this laptop is that in entirety, it weighs a mere two kg. It is undoubtedly the world’s lightest and thinnest 15.6-inch laptop. The X600, although thin, has not compromised its technology in the slightest; it is precision design, down to the last detail.
The X600 embeds ATi Mobility Radeon HD 4330 3D graphics card with 512 MB VRAM, providing support for millions of colors, brilliant detail and breathtakingly vivid effects. The 15.6-inch LCD widescreen glossy display makes watching high definition DVDs or gaming a real pleasure, as it brings you one step closer to your viewing experience.
The X600 is embedded with LED power-saving backlight technology to provide better color fullness and brightness, elevating the total quality of imagery. Furthermore, the lower usage of power can offer a longer operating time.
MSI exclusive VIVID technology is able to display signals that allow for richer colors, making the X600 has one of the most stunningly dramatic screens on the market, bringing even the smallest details to life. Regardless of whether you’re gaming, editing images, or simply watching movies, your experience will be incredibly realistic.
Features:-
- 4GB of Memory
- 500GB HDD
- 15.6” 16:9 Wide Screen Display (1366*768)
- ATi Mobility Radeon HD 4330 Graphics Card with 512 MB VRAM
- WiMAX™ Wireless Module (optional)
- 6 Cell Battery (upto 8hr battery life)
- 2 years Warranty
Was £468.83 Inc. VAT
Only £446.49 inc VAT.
ORDER NOW
AMD Phenom II X2 Dual Core 555 3.20GHz Black Edition (Socket AM3) - Retail @ £65.79 inc VAT
AMD Phenom II Dual-Core processors put the power of dual-core technology on the desktop. Dual-core processors contain two processing cores, residing on one chip, that perform calculations on two streams of data to increase efficiency and speed while running multiple programs and the new generation of multi-threaded software. AMD Phenom II Dual-Core processors deliver TRUE multi-tasking, allowing users to switch from one program to another without always pausing for the computer to catch up and reducing annoying processing pauses.
- Dual-core Technology
- 3.20Ghz clock speed (AM3 Socket)
- Multiplier unlocked
- 7.0MB L2+L3 Cache
- Cool & Quiet Technology for Energy Efficiency
- Enhanced Virus Protection
- 64-bit Technology
- Hyper Transport Technology
- Virtualization technology
- Unlocked Multiplier
- 3yr Warranty
- Retail Boxed with Heatsink & Fan
Was £68.14 Inc. VAT
Only £65.79 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 965 Black Edition "125W Edition" 3.40GHz (Socket AM3) - Retail @ £123.36 inc VAT
The AMD Phenom II processors are the most advanced processors for true multitasking offering true quad-core design. AMD Phenom II processors deliver virtually uninterrupted information flow between processor cores, main memory and graphics and video accelerators for amazingly rapid system response and phenomenal system performance. AMD Phenom II processors deliver unbeatable multi-core value with superior high definition computing, advanced multitasking performance, and innovative, energy efficient solutions.
- 3.40GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology (125W Edition)
- True Multi-core Processing
- Direct Connect Architecture
- Integrated Dual-Channel Memory Controller with up to DDR3-1333 support
- HyperTransport 3.0
- AMD Balanced Smart Cache
- AMD Wide Floating Point Accelerator
- AMD Memory Optimizer Technology
- AMD Digital Media Xpress 2.0
- AMD Virtualization with Rapid Virtualization Indexing
- Cool‘n’Quiet 3.0 technology
Was £135.11 Inc. VAT
Only £123.36 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1055T 2.80GHz (Socket AM3) - Retail @ £140.99 inc VAT
Six-core processing power for massive performance headroom - at the price of the competition's quad-core products. The AMD Phenom II X6 processor features AMD Turbo CORE technology that enables unlocked performance for cutting-edge applications, and dynamically switches to three cores for raw speed. Direct Connect Architecture that enables leading-edge performance and responsiveness, even on the most demanding applications. HyperTransport 3.0 Technology enables incredible system agility for 3D gaming and ultra-high resolution entertainment. AMD Dedicated Multi-cache that extends the memory bandwidth for intensive applications, delivering fast performance per core.
- Six Core Technology
- 2.80GHz Clock Speed
- 4.0 GT/s System Bus
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
Was £149.99 Inc. VAT
Only £140.99 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1090T Black Edition 3.20GHz (Socket AM3) - Retail @ £176.24 inc VAT
- Multiplier Unlocked
- 3.20GHz Clock Speed
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- 3 Year Warranty
Only £176.24 inc VAT.
ORDER NOW
AMD Athlon 64 X2 Dual Core 7850+ Black Edition 2.80GHz (Socket AM2+) - OEM @ £41.11 inc VAT
AMD Athlon Dual-Core processors put the power of dual-core technology on the desktop. Dual-core processors contain two processing cores, residing on one chip, that perform calculations on two streams of data to increase efficiency and speed while running multiple programs and the new generation of multi-threaded software. AMD Athlon Dual-Core processors deliver TRUE multi-tasking, allowing users to switch from one program to another without always pausing for the computer to catch up and reducing annoying processing pauses.
- 2.80Ghz clock speed (AM2 Socket)
- 3.0MB Total Cache (L2+L3)
- 64-bit Technology
- Please note this is an OEM part and does not come with a heatsink.
Was £46.99 Inc. VAT
Only £41.11 inc VAT.
ORDER NOW
AMD Phenom X4 Quad Core 9850+ 2.50GHz (Socket AM2+) - OEM @ £63.44 inc VAT
The AMD Phenom processors are the most advanced processors for true multitasking offering true quad-core design. AMD Phenom processors deliver virtually uninterrupted information flow between processor cores, main memory and graphics and video accelerators for amazingly rapid system response and phenomenal system performance.
- True Quad-core Desktop Processor
- 2.50GHz clock speed
- 2MB L2 cache
- 2MB L3 cache
- DDR2-1066 support
- 65nm process technology
- Integrated Memory Controller
- Fast Hypertransport 3.0 technology
- Cool & Quiet v2.0
Was £70.49 Inc. VAT
Only £63.44 inc VAT.
ORDER NOW
Corsair Dominator GT 6GB (3x2GB) DDR3 PC3-16000C8 2000MHz Triple Channel Kit (CMT6GX3M3A2000C8) @ £176.24 inc VAT
The DOMINATOR-GT is the ultimate performance memory solution. Limited to only extremely high memory speeds, the Corsair DOMINATOR-GT only uses highly screened IC's to guarantee performance and over-clockability. Using ultra efficient Dual-path Heat Xchange (DHX) cooling technology. With removable heat sinks, the DOMINATOR-GT modules can even be outfitted with additional upcoming accessories with enhanced features. Includes Airflow fan.
- Three matched 2GB modules for use in high performance Intel Core i7 Triple Channel systems
- Outrageously fast 2000MHz performance using 6GB of memory
- Ultra-low 8-9-8-24 latency
- Intel XMP (Extreme Memory Profile) Support
- Airflow Fan
- Density: 6GB (3x2GB Module)
- Speed: 2000MHz
- Timing: 8-9-8-24
- Pin Voltage: 1.65V
ORDER NOW
Corsair Dominator 6GB (3x2GB) DDR3 PC3-12800C7 1600MHz Triple Channel Kit (CMP6GX3M3A1600C7) @ £135.11 inc VAT
The Dominator is the ultimate performance memory solution. Limited to only extremely high memory speeds, the Corsair Dominator only uses highly screened IC’s to guarantee performance and over-clockability. Using ultra efficient Dual-path Heat Xchange (DHX) cooling technology. With removable heat sinks, the Dominator modules can even be outfitted with additional upcoming accessories with enhanced features.
- Outrageously fast 1600MHz performance
- 1.65V
- Ultra-low 7-8-7-20 latency
- Dominator DHX Heatspreaders.
Only £135.11 inc VAT.
ORDER NOW
Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel (CMX6GX3M3A1600C9) @ £88.11 inc VAT
The XMS Series CMX6GX3M3A1600C9 is a 6144MByte kit of DDR3 SDRAM DIMMs built using Corsair’s high performance heat sink which includes Intel’s Extreme Memory Profiles (XMP 1.2). This part delivers outstanding performance in the latest generation of X58 DDR3-based motherboards. It has been tested extensively in popular X58 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1600MHz at latencies of 9-9-9-24 at 1.65V VDIMM.
- Each three module set is tested at 1600MHz
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.65V, at latency settings of 9-9-9-24 on Intel X58 DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.65V
- 6144 Megabytes of DDR3 memory
- 100% tested at 1600MHz in X58-based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
Was £99.99 Inc. VAT
Only £88.11 inc VAT.
ORDER NOW
Corsair Dominator 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMD4GX3M2A1600C9) @ £70.49 inc VAT
This 4GB twin DOMINATOR kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock.
- Corsair Dominator memory (2 x 2GB)
- Form factor: DIMM 240-pin
- Memory speed: 1600 MHz
- Latency timings: CL9 (9-9-9-24 )
- Dual-path Heat Xchange (DHX)
- Intel Extreme Memory Profiles (XMP)
- Supply voltage: 1.65 V
- Built for Intel
Was £75.99 Inc. VAT
Only £70.49 inc VAT.
ORDER NOW
Corsair Dominator 4GB (2x2GB) DDR2 XMS2 PC2-8500C5 TwinX (TWIN2X4096-8500C5D) @ £99.99 inc VAT
The Dominator Series Twin2X4096-8500C5DF is 4096MBytes of DDR2 SDRAM DIMMs built using Corsair’s latest high performance heat sink with Dual-Path Heat Xchange (DHX) technology coupled with a Corsair Dominator Airflow Fan. This memory has been verified to operate at 1066MHz at latencies of 5-5-5-15-2T at 2.1VDIMM. The Twin2X4096-8500C5DF comes with Enhanced Performance Profiles (EPP), the open standard for performance module SPD’s jointly developed by Corsair and NVIDIA. EPP SPD’s on Corsair modules allow users to automatically configure EPP enabled motherboards with aggressive memory performance settings, for maximum memory and system performance.
- Enhanced Performance Profiles allow automatic overclocking to aggressive performance settings
- 100% tested at 1066MHz in high performance DDR2 motherboards
- Lifetime warranty
Was £129.99 Inc. VAT
ORDER NOW
Corsair XMS2 4GB (2x2GB) DDR2 PC2-6400C5 TwinX Dual Channel (TWIN2X4096-6400C5C) @ £65.79 inc VAT
The XMS brand family is Corsair's mainstream line of performance memory. These modules allow users to experience outstanding memory performance and stability.
- Two matched 2GB modules for use AMD and Intel DDR2 systems
- Mainstream 800MHz solutions
- Latency of 5-5-5-18 for maximum reliability and performance
- XMS Heat Spreader
- Limited Lifetime Warranty
- Density: 4GB (2x2GB Module)
- Speed: 800MHz
- Timing: 5-5-5-18
- Type: DDR2
- Format: DIMM
- Pin Out: 240 Pin
- Voltage: 1.8V
Was £69.99 Inc. VAT
ORDER NOW
MSI GeForce GTX 470 Twin Frozr II 1280MB GDDR5 PCI-Express Graphics Card with MAFIA 2 ***OcUK Exclusive*** @ £205.61 inc VAT
nonl2br
<font size="4"><b>Key Features</b></font><br>
<br>
<b>Twin Frozr II Thermal Design - Reduces Heat by 16C and Noise by 21.5dB</b><br>
- Dual 8CM PWM Fans : Air flow from dual fans can cool down GPU/Memory/Power Module at once.<br>
- Five heat pipes with SuperPipe Technology<br>
- Nickel-plated Copper Base : Large size of Copper Base can dissipate the heat of GPU faster.<br>
<br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/vga/400/465TF_1.jpg" align="left" alt="MSI" />
<img src="http://eu.msi.com/uploads/Image/product_img/other/vga/400/465TF_2.jpg" align="left" alt="MSI" />
<img src="http://eu.msi.com/uploads/Image/product_img/other/vga/400/465TF_3.jpg" align="left" alt="MSI" /><br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/vga/military_f.gif" align="right" alt="MSI" />
<b>Military Class Components</b><br>
- Hi-C Cap provides more precise GPU voltage.<br>
- SSC (Solid State Chock) has No Buzz noise and higher current for better overclocking ability.<br>
- All Solid CAP for longer lifespan. <br>
<br>
<b>Over voltage function of GPU</b><br>
- Supports over voltage function of GPU by Afterburner, and performance can be up to 15%! <br>
<br>
<b>PhysX & 3DVision Surround technology</b><br>
- Support PhysX technology effects for realist physics effect.<br>
- Support 3DVision Surround technology to provide 3 monitor output simultaneously and real 3D image experience. (3D Vision surround for 3 monitors require 2 cards running in SLI mode to work. Need to work with 3D monitor and 3D glass.) <br>
<br>
<br>
<img src="http://eu.msi.com/uploads/features/features_s113_20080924184632.gif" align="left" alt="MSI" />
<img src="http://eu.msi.com/uploads/features/features_20091001175634.gif" align="left" alt="MSI" />
<img src="http://eu.msi.com/uploads/features/features_s73_20070827185455.gif" align="left" alt="MSI" />
<img src="http://eu.msi.com/uploads/features/features_20091001175702.gif" align="left" alt="MSI" />
<img src="http://eu.msi.com/uploads/Image/product_img/other/vga/400/3d_v.jpg" align="left" alt="MSI" /><br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<font size="4"><b>Specifications</b></font><br>
- Voltage Tweak Technology<br>
- Twin FrozR II 5 Heatpipe Dual Fan SILENT Cooler<br>
- Extreme OC Potential (Voltage tweak, Military capacitors, uprated cooling)<br>
- Core Clock: 607MHz<br>
- Memory: 1280MB GDDR5<br>
- Memory Clock: 3348MHz (Effective)<br>
- Memory Interface: 320-Bit<br>
- Processing Cores: 448<br>
- Shader Clock: 1215MHz<br>
- Bus Type: PCI-Express 2.0<br>
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)<br>
- SLI Ready<br>
- HDCP Capable<br>
- DirectX 11 Support<br>
- OpenGL 3.1 Support<br>
- PhysX Enabled<br>
- CUDA Enabled<br>
- Warranty: 2 Years<br>
- Supplied with Full Mafia 2 PC Game as of 27/08/2010 (This is a highly anticipated game thats in huge demand and with this product you get a download voucher which entitles you to download the full version of this game for FREE. This game has an RRP of £29.99!!)
- Warranty: 2 Years
Was £220.00 Inc. VAT
Only £205.61 inc VAT.
ORDER NOW
Asus GeForce GTX 460 Direct CU TOP 768MB GDDR5 PCI-Express Graphics Card with HAWX2 PC-Game @ £111.61 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Exclusive Voltage Tweak Technology
- Core Clock: 700MHz
- Memory: 768MB GDDR5
- Memory Clock: 3680MHz (Effective)
- Memory Interface: 192-Bit
- Processing Cores: 336
- Shader Clock: 1400MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a
- SLI Ready
- HDCP Capable
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
- Supplied with Full TOM CLANCY's HAWX2 PC Game as of 18/10/2010 (This is a highly anticipated game thats in huge demand and with this product you get a download voucher which entitles you to download the full version of this game for FREE. This game has an RRP of £29.99!!)
ORDER NOW
Asus GeForce GTX 460 1024MB DirectCU TOP GDDR5 PCI-Express Graphics Card with HAWX2 PC-Game @ £158.61 inc VAT
- ASUS Exclusive DirectCU Thermal Solution: Three 8mm flattened copper heat-pipes contact GPU directly and reach up to 20% COOLER than generic GeForce GTX460
- Over-clocked with 775 MHz engine clock for reaching 115% performance
- ASUS Exclusive Voltage Tweak Technology for up to 50% performance
- Core Clock: 775MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Memory Interface: 256-Bit
- Shader Clock: 1550MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Was £169.99 Inc. VAT
ORDER NOW
OcUK GeForce GT 430 1024MB GDDR3 Low Profile PCI-Express Graphics Card @ £52.86 inc VAT
The GT430 provides users with ultra-smooth multimedia entertainment. This makes it the ideal product for a home theatre PC. Accompanied by a low profile design and Blu-ray 3D acceleration the GT430 has the perfect compatibility and fit required for HTPCs and multimedia centres. The GT430 plays Blu-ray 3D playback with true HD and put's minimal stress on the CPU allowing crisp, clear viewing in excellent detail.
Specification:-
- Memory: 1024MB GDDR3
- Memory Clock: 1600MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 96
- Display Connectors: 1x Dual-Link DVI-I, 1x Analogue & 1x HDMI
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Dimensions: The card size is 6.3 inches x 2.8 inches
- Warranty: 2 Years
Was £56.99 Inc. VAT
Only £52.86 inc VAT.
ORDER NOW
XFX ATI Radeon HD 5830 1024MB GDDR5 PCI-Express Graphics Card supplied with AVP PC-Game @ £123.36 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 5830 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 800MHz
- Processing Cores: 1120
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- Warranty: 2 Years
- Includes Alien vs Predator Voucher Code
***EXCLUSIVE Premium Priority 2 Year Warranty***
In the unlikely event of your card failing within 2 Years, OcUK will replace your card with a brand new one, pending testing within our standard RMA terms and conditions (http://www.overclockers.co.uk/support.php)
Was £145.00 Inc. VAT
ORDER NOW
HIS ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card @ £93.99 inc VAT
Now, more people than ever can experience real innovation in DirectX 11 gaming with ATI Radeon HD 5700 Series graphics processors. Loaded with advanced technology, these GPUs have the power and premium features you need for fully immersive gameplay. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first GPUs in this class to offer full support for DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 850MHz
- Memory Clock: 4800MHz (Effective)
- Memory Bandwidth: 76.8GB/s
- Processing Cores: 800
- Display Connectors: 1 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Year
Was £99.99 Inc. VAT
Only £93.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 5750 XXX 1024MB GDDR5 PCI-Express Graphics Card ***OcUK Exclusive*** @ £82.24 inc VAT
A single-slot card variant of the 5700 performance card family, it sports a uniquely designed fansink, with thermal capability of the HD 5750 dual slot channel fansink. This, combined with the open space provided by the single slot environment, ensures maximum airflow to the GPU.
An acoustic comparison of the 5700 family found that the XFX ATI Radeon HD 5750 single slot was much lower than the HD 5750 dual slot full cover fansink. Enhanced cooling and reduced noise is helped by fan speed. For gamers who have been waiting for the ideal single-slot graphics card, the XFX ATI Radeon HD 5750 has been worth the wait. The unique cooling capacity—and reduced noise levels—of this single-slot solution makes this a very attractive graphics card indeed. To optimize your gaming experience further, the overclocked XXX variant is also available.
ATI Eyefinity Technology allows two or more display outputs operating simultaneously and cooperatively with one another. Support is available for Duplicated (Clone), Extended Monitor and Single Large Surface mode (SLS). SLS mode is capable of grouping multiple displays into a massive single large display for use with desktop workspace, video playback, with support for both windowed and full screen 3D applications.
- Core Clock: 740MHz
- Processing Cores: 720
- Display Connectors: 2 Dual-Link DVI-I, & 1 Mini-DisplayPort
- HDCP Capable
- ATI Avivo HD
- Single Slot
- Supplied with Call of Duty Modern Warfare 2 Free Download Voucher
Was £89.99 Inc. VAT
Only £82.24 inc VAT.
ORDER NOW
Intel X25-V Value 40GB 2.5" SATA-II Solid State Hard Drive (SSDSA2MP040G2R5) with FREE Games - Retail @ £70.49 inc VAT
nonl2br
<b>On purchase of this SSD Hard Drive, you will be sent a voucher code to claim a free download of one of the below PC games:</b> <br>
<br>
• R.U.S.E - The Art of Deception<br>
• Assassin’s Creed 2 (Standard Edition)<br>
• Far Cry® 2 - Fortunes Edition<br>
• Call of Juarez 2 - Bound in Blood<br>
• Tom Clancy's Rainbow Six® - Vegas 2<br>
<br>
<b>One code per order.</b><br>
<br>
Intel Value Solid-State Drives represent an advancement in storage technology that is specially engineered to deliver robust performance for cost effective solutions. Intel X25-V SSD was created to take on the most demanding applications your netbook or notebook PC has to offer, at a significant value for solid-state computing. It also provides a high-performance reliable boot drive for desktop and embedded applications.
<br>
<br>
- Capacity: 40GB<br>
- Controller: Intel<br>
- Read: Up to 170MB/sec<br>
- Write: Up to 35MB/sec<br>
- NAND Flash: 34nm Multi-Level Cell (MLC)<br>
- Interface: SATA-II<br>
- Low Power Consumption<br>
- Lightweight (68g)<br>
- Shock Resistant<br>
- Retail SKU Supplied with mounting brackets.<br>
- Also supplied with Lost Planet 2 PC Game download voucher
Was £74.99 Inc. VAT
ORDER NOW
Intel X25-M Mainstream 80GB 2.5" SATA-II Solid State Hard Drive (SSDSA2MH080G2R5) with FREE Games - Retail @ £135.11 inc VAT
nonl2br
<br>
<br>
<br>
Intel Solid-State Drives represent a revolutionary breakthrough that delivers a giant leap in storage performance. Intel Solid-State Drives are designed to satisfy the most demanding gamers, media creators, and technology enthusiasts. These new drives bring a high level of performance and reliability to notebook and desktop PC storage, at a fraction of the cost of the previous generation of Intel SSD products. Drawing from decades of memory engineering experience, and new, industry-leading compute-quality 34nm NAND flash memory manufacturing processes, Intel Mainstream SATA SSDs are designed to deliver outstanding performance, featuring the latest-generation native SATA interface with an advanced architecture employing 10 parallel NAND flash channels equipped with multi-level cell NAND flash memory. With powerful Native Command Queuing to enable up to 32 concurrent operations, Intel Mainstream SATA SSDs deliver higher input/output per second and throughput performance than other SSDs on the market today - and drastically out-perform traditional hard disk drives. These drives also feature low write amplification and a unique wear-leveling design for higher reliability, meaning Intel drives not only perform better - they last longer.
<br>
<br>
- Capacity: 80GB<br>
- Read: Up to 250MB/sec<br>
- Write: Up to 70MB/sec<br>
- Lightweight (80g)<br>
ORDER NOW
OCZ IBIS 100GB 3.5" HDSL Super-Fast Solid State Hard Drive @ £340.74 inc VAT
The OCZ IBIS solid-state drive is a ground-breaking product on two levels - the storage level and interfacing level. Unsatisfied with current storage interface options, OCZ developed High Speed DataLink or HSDL, to eliminate the existing I/O bottle necks and take SSDtechnology to new heights. As the first SSD to make use of the proprietary HSDL interface, the IBIS is capable of delivering incredible, trailblazing performance (740MBps read/writespeeds and upto 120,000 randomwrite IOPS). IBIS SSDs willbe available in a complete spectrum of capacities ranging from 100GB to 960GB. Each IBIS comes in a durable aluminum 3.5inch housing and is bundled with a singleport HSDL adapter card.
Features:-
- Max Read: up to 740MB/s
- Max Write: up to 690MB/s
- Sustained Write: up to 550MB/s
- Random Write 4KB (Aligned): 100,000 IOPS
- Available in 100GB to 960GB capacities
- 4x SandForce 1222 Controllers (Onboard RAID 0)
- Max IOPS Firmware
- Seek Time: 0.1ms
- 3.5" Anodized Casing
- 146 (L) x 101.6 (W) x 25.40mm (H)
- Operating Temp: 0°C ~ 70°C
- Storage Temp: -45°C ~ +85°C
- Low Power Consumption: 2W in operation,.5W in standby
- Shock Resistant up to 1500G
- Compatible with Windows XP, Vista, 7, Mac OS X and Linux
- MTBF: 2 million hours
- Ideal for desktop systems (no need for converter brackets)
- Bundled with a single port HSDL adapter card (Bootable)
- 3-Year Warranty
Was £379.99 Inc. VAT
Only £340.74 inc VAT.
ORDER NOW
OCZ Vertex 2E 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE60G) @ £91.64 inc VAT
Based on a cutting-edge new architecture, Vertex 2 Solid State Drives raise the bar once again and deliver unprecedented performance for the complete gamut of gaming and professional multimedia applications. OCZ designed the Vertex 2 to surpass the competition where it counts most, pushing the limits in both sequential and random read/write rates. With spectacular performance in 4k file writes up to 50,000 IOPS, these latest drives take productivity to the next level with over ten times the performance of the previous generation. Using the latest controller technology, Vertex 2 not only provides a faster, more responsive PC experience, but promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. OCZ Vertex 2 SSDs come backed by a 3-year warranty and 2 million hour MTBF for ultimate peace of mind.
- Capacity: 60GB
- Controller: SandForce SF-1200
- Maximum Read: 285MB/sec
- Maximum Write: 275MB/sec
- Sustained Write: 250MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Only £91.64 inc VAT.
ORDER NOW
Intel X25-M Mainstream 120GB 2.5" SATA-II Solid State Hard Drive (SSDSA2MH120G2K5) with FREE Games - Retail @ £176.24 inc VAT
nonl2br
<br>
<br>
<br>
<br>
<br>
- Capacity: 120GB<br>
Was £184.99 Inc. VAT
ORDER NOW
OCZ Vertex 2E 240GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE240G) @ £340.74 inc VAT
- Capacity: 240GB
- Warranty: 3 Years
Was £370.00 Inc. VAT
ORDER NOW
Coolermaster Storm Scout Gaming Case - Black @ £54.99 inc VAT
CM Storm is celebrating the deployment of the Scout™ true gaming chassis, created in close cooperation with the world’s leading professional gaming teams and eSports organizers, including Kode5, Team Fnatic and mousesports. Like all gear developed in the CM Storm Labs, the Scout has been heavily injected with Storm Tactics™ to ensure complete Strength, Security, and Control to the discerning gamer. Developed with elite engineering skills, and reinforced by the highest grade materials, your Storm gear will perform and deliver with unfailing reliability, letting you focus on your game and worry less about your hardware. The Scout has been built around a solid steel body, and comes equipped with a 140mm front intake fan, as well as 140mm top and 120mm rear exhaust fans, providing an accurate airflow to efficiently manage the heat from your gaming hardware. The aggressive window side panel, with its dark automotive tint, provides mounting locations for yet another 2 x 120mm fans to deal with thermal hotspots from overclocked CPUs and GPUs. The Scout has been fortified even further with the patented StormGuard™ accessory; this unique and widely acclaimed security solution from the CM Storm Labs consists of a specially designed PCI-bracket located at the rear of the chassis body. By locking your peripherals and side panel firmly in place, Storm Tactics and the StormGuard will protect your PC and gaming gear from thieves and other thuggish individuals whenever you are AFK. Never again return to your seat at a LAN-party, only to find that some villain has grabbed your gaming mouse and headset, or even worse, your entire system.
- Solid Steel Body for strenght and stability
- Features sturdy carry handles for taking to your favourite LAN events
- Unique security feature protection for your system and peripherals
- 4 x 5.25" drive bays
- 5 x 3.5" drive bays
- Bottom mounted PSU support
- Front I/O Port: eSata, FireWire, 4 x USB, HD audio
- Front Cooling: 140mm intake fan (included)
- Top Cooling: 140mm exhaust fan (included)
- Rear Cooling: 120mm exhaust fan (included)
- Side Cooling: 2 x 120mm intake fan (optional)
Was £60.99 Inc. VAT
Only £54.99 inc VAT.
ORDER NOW
Silverstone RV02 Raven 2 Case - Black @ £132.99 inc VAT
After releasing the ground-breaking RAVEN RV01, the first retail chassis to utilize the 90 degree motherboard mounting layout, SilverStone’s RAVEN team quickly went back to the drawing board to create another chassis with even more mass appeal. The resulting RAVEN RV02 is smaller, lighter, and higher performing. Compatibility with Extended-ATX motherboard and server level storage capacity were sacrificed in favor of a more compact dimension and consumer oriented design. Three custom designed 180mm fans and one 120mm fan are included in the RV02 to provide noise to cooling performance ratio that breaks existing benchmark for enthusiast chassis. Additional features such as the inclusion of the 8th expansion slot (for triple or quad graphics cards), all black painted interior, custom designed hard drive suspension cage, and radiator mounts completes a package that will not only appeal to hardware enthusiasts but also to anyone looking to assemble a system that makes a statement with plenty of cooling and very little noise.
- Material: Reinforced Plastic Shell, with Steel body
- Motherboard Compatability: ATX, MicroATX
- Drive Bays: 8 x 5.25"
- Drive Bays: 3 x 3.5"
- Drive Bays: 1 x 2.5"
- Cooling: 1 x 120mm top exhaust fan, 3 x 180mm bottom intake fans
- Front I/O: 2 x USB2.0 and 2 x Audio
- Dimensions: 212 x 503 x 643mm (W x H x D)
Was £142.99 Inc. VAT
Only £132.99 inc VAT.
ORDER NOW
OCUK EZCool NA-705 Case - Black (500w PSU) @ £19.99 inc VAT
The NA-705 is an entry level range which meets the latest thermal requirements.
- Front Panel-Light up Blue highlight LED
- CPU support: Dual Core
- Driverbay: 3*5.25 external
- 1 x 3.5 external
- 4 x 3.5 internal
- Chassis-1 x80mm rear fan Space: 1 x 80mm front fan space
- Fan Duct
- Compatible M/B : MATX
- Riveted 0.6mm Japanese SECC metal frame in metallic silver PSU- 500w
- Dimensions: 180mm 445mm 410mm (W x D x H)
Was £21.98 Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
Corsair HX 1000W ATX Modular SLI Compliant Power Supply (CMPSU-1000HXUK) @ £167.64 inc VAT
The HX1000W joins the family of well received HX Series Enthusiast Grade Power Supplies known for their rock solid stability, enhanced modular cable design and high efficiency. The Corsair HX1000W Power Supply sets a new standard by which all other high wattage power supplies will be judged. The Corsair HX1000W features six PCI-Express connectors, both 6-pin and 8-pin compatible, to power multiple high-end graphics cards and two EPS12V connectors for dual CPU configurations. The truly independent dual transformer, dual rail design allow for optimum load balancing resulting in greater performance and stability. Industrial-grade 105°C primary, secondary and solid state capacitors provide up to four times the lifespan of traditional components. The HX1000W not only delivers one thousand watts of clean power for the highest performance enthusiast systems, it does so at greater than 80% efficiency thanks to the double-forward switching design and multiple rail DC-to-DC converter. Due to its best-in-class efficiency the HX1000W is able to run cool and quiet with only a single 140mm thermally controlled fan.
- Guaranteed to deliver 1000W of continuous power at 50°C
- 80%+ energy efficient under real world load conditions
- True independent dual rail design for maximum compatibility
- Combined 80A of power on +12V
- Multiple GPU ready
- 105°C solid state capacitors
- Active Power Factor Correction (PFC) with PF value of 0.99 to ensure clean and reliable power
- Supports the latest ATX12V 2.2 and EPS12V 2.91 Standards. Backwards compatible with ATX12V 2.01
- Auto switching circuitry provides universal AC input 90-264V
- Over Current/Voltage/Power Protection, Under Voltage Protection and Short Circuit - Protection provide maximum component safety
- Dimensions: 150mm(W) x 86mm(H) x 200mm(L)
- Five year limited warranty with 24/7 on demand customer service
- MTBF: 100,000 hours
Only £167.64 inc VAT.
ORDER NOW
Logitech MX518 Gaming-Grade Optical Mouse (910-000616) @ £21.98 inc VAT
The Logitech® MX™518 optical gaming mouse gives gamers a precision advantage. Its 1800 dpi optical engine delivers pinpoint accuracy. A sculpted comfort grip helps reduce strain, and slick polytetrafluoroethylene feet glide smoothly across almost any surface. In-game sensitivity switching lets you easily control cursor speed and responsiveness without ever having to interrupt play.
- 1800 dpi optical engine - Delivers precision targeting and pinpoint accuracy
- Sculpted comfort grip - Helps reduce strain
- Polytetrafluoroethylene feet - Glide smoothly across almost any surface
- In-game sensitivity switching - Lets you easily control cursor speed and responsiveness without ever having to interrupt play
- Eight programmable buttons - Provide added control and efficiency
- 3-year limited warranty
Was £24.99 Inc. VAT
Only £21.98 inc VAT.
ORDER NOW
Saitek Cyborg R.A.T. 7 5600 DPI Gaming Mouse @ £69.98 inc VAT
Play to win with the R.A.T. 7. Uncompromising, unparalleled, and unmatched, the R.A.T. 7 helps you play like the pros, combining state-of-the-art technology with a jaw-dropping array of customizable features to produce the next step in the evolution of the mouse. Perfect your grip – How do you hunt? Whether you ‘palm’ the mouse or ‘claw’ it, the R.A.T. can quickly and easily adapt by adjusting in length to suit your hand size and grip style. In addition, the Thumb Panel of the R.A.T. 7 moves forwards, backwards, and pivots outwards, giving you perfect positioning for effortless gaming.
- 3 Palm Rests: One featuring the same soft-touch finish as found on the body of the R.A.T., one with a rubber inlay for enhanced grip and one that is 4mm thicker to increase the height of the R.A.T.
- 3 Pinkie Grips: One featuring the same soft-touch finish as found on the body of the R.A.T., one with a rubber inlay for enhanced grip and one that offers a ‘wing shaped’ design, allowing you to rest your pinkie finger during play for increased grip.
- Custom Weight System – Like it light or heavy? Maybe you change the weight to suit your game? No matter, the R.A.T. has you covered. Five 6-gram weights can be added or subtracted in an instant, giving you the perfect weight for a perfect feel. When not in use, the weights can be safely stored in the supplied Weight Storage Container.
- Precision Aim Mode – Hit your target the first time every time. Use the ST Programming Software to set your desired Precision Aim speed (mouse sensitivity), then hold down the Precision Aim button to slow down mouse movement to a level that works for you. A deadly weapon that will hit your enemy where it hurts.
- 5600 DPI – Featuring a new generation ‘twin eye’ laser sensor that reads each axis separately for pinpoint accuracy, the R.A.T. 7 tracks up to a stunning 6 meters per second. Pro gamers who favor low sensitivity with high movement speed preferences will always experience correct tracking and precision.
- 4 Custom DPI Settings – Use the Rocker Switch to toggle between your custom DPI settings.
- 5 Programmable Buttons – Combine your Programmable Buttons with 2 regular left and right mouse buttons and give yourself a total of 7 buttons available to punish your competition. Assign your choice of key gaming actions to Programmable Buttons to create your own custom profiles.
- 3 Cyborg Modes – Toggle between three individual R.A.T. modes at the touch of a button. Change sensitivity or Programmable Button actions in an instant and gain immediate access to a mind-boggling 15 commands!
- Powerful ST Programming Software – Change your DPI, set Precision Aim cursor sensitivity, create custom profiles for each game, and assign commands to your Programmable Buttons and Modes. Easy, quick and the power you need right on your desktop.
- Lightweight Metal Chassis – Strong yet nimble, the solid metal frame forms the core of the R.A.T. 7 for enhanced rigidity.
- DPI range – 25-5600dpi (in 25dpi steps)
- Acceleration – 50G
- Polling Rate – Dynamic up to 1000Hz
- Tracking Speed – Up to 6m/sec
- Always On – Yes
- PTFE Slick Feet
- Gold plated connector – Yes
- Braided cable - Yes
Was £74.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Prolimatech Megahalems Rev B CPU Cooler (Socket 775/1156/1366) @ £42.98 inc VAT
The tower type coolers have been the mainstream in the CPU cooling market for quite some time now, but upon closer inspection you start to notice that designs and engineering can only go so far as they are slowly come to a bottleneck. After a while they all start to look the same with performance not worth popping the champaign. This is where Prolimatech comes in. We are here to challenge all possible odds and stray away from the norm. With that focus in mind comes the new Megahalems, tower CPU cooler. Never before seen are the new lows in temperature produced by an intelligent design of low air flow resistance with unmatched performance to boost; perfect for the true overclockers in all of us.
- Heatsink Dimension (L)130mm X (W)74mmX (H)158.7mm
- Heatsink Weight 790g
- Heatpipe Ø 6mm X 6pcs
- Suggest Fan 120mm X 120mm X25mm
- Suggest Fan Speed 800~1200rpm
- Suggest Noise Level (dBA) Below 26dBA
- Direction of heatsink faces the rear exhaust system fan
Was £46.86 Inc. VAT
Only £42.98 inc VAT.
ORDER NOW
AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) - Retail @ £39.99 inc VAT
AMD Athlon II Dual-Core processors put the power of dual-core technology on the desktop. Dual-core processors contain two processing cores, residing on one chip, that perform calculations on two streams of data to increase efficiency and speed while running multiple programs and the new generation of multi-threaded software. AMD Athlon II Dual-Core processors deliver TRUE multi-tasking, allowing users to switch from one program to another without always pausing for the computer to catch up and reducing annoying processing pauses.
- 3.00Ghz clock speed (AM3 Socket)
- 2.0MB L2 Cache
- 64-bit Technology
- 3yr Warranty
Was £41.99 Inc. VAT
Only £39.99 inc VAT.
ORDER NOW
Benq XL2410T 24" TRUE 120Hz 3D Widescreen LED Monitor - Black @ £284.98 inc VAT
BenQ, proudly announced the release of their 23.6” (16:9 Aspect Ratio) LED Gaming Monitor XL2410T. BenQ understands that to lead and become a true and professional gaming monitor provider, they have to understand the mindset and needs of gamers. In order to achieve this goal, BenQ co-worked with ZOWIE, a professional Gaming gear manufacturer. BenQ have ZOWIE’s gamer teams join in during the product development and testing stages. With their assistance, XL2410T can truly be a professional LED gaming monitor – with a set of Gaming Display Modes which includes the FPS mode (First Person Shooting), co-developed by two legendary Counter-Strike players – Emil “HeatoN” Christensen and Abdisamad “SpawN” Mohamed.
Every serious gamer know that lag will cause you to lose a game; XL2410T is made to have a quick response to action, hardware lag will no longer be the cause for your headshots. XL2410T has a fast refresh rate of 120Hz for higher precision; a low input lag so the shots made is more in sync with the visual on-screen; a quick 2ms GTG (OverDrive) meaning users can see the edge of the enemies clearly and without motion blur, and Dynamic Contrast Ratio of 10,000,000:1 for detailed images and clarity in both darkened and brightened situations, this complemented with BenQ’s gaming tuning technology becomes a huge advantage for gamers.
XL2410T has a smart design, for one purpose – to win. The monitor has two hotkeys available; the first changes the display mode: Full; Aspect; Overscan; 1:1; 17”; 19”; 19” Widescreen and 22” Widescreen. Whereas the second hotkey is Smart Scaling, which lets the users adjust picture size in original input to the screen’s limit. Together with Display Mode function, users can play in the resolution size they are used to with their previous monitor, or adjust their screen size to what their teammates are using for easier communication and reference. From BenQ’s Gaming Display Modes options, users can choose from FPS Mode, made possible by co-working with the gaming heroes -HeatoN and Spawn as the best setting for personal shooting games, or from the two User Game modes for more dedicated and personalized settings.
For extreme entertainment, XL2410T is the LED monitor to go for. 3D-ready (NVIDIA 3D Vision certified); Picture by Picture (PBP); connectivity values (D-sub; DVI-D-DL, HDMI) and height adjustment feature are offered for users’ enjoyment and comfort. Picture by picture (PBP) is a feature that enables users to show two programs side-by-side on the screen. Feel like camping once in a while for fun? Watch a movie while you do it!
- LED Backlit
- Screen Size: 23.6" Widescreen
- Contrast Ratio: 10000000:1
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- VESA Compliant
- Weight: 6.0kg
- Height adjustable stand / Swivel 45/45 left/right
Was £319.99 Inc. VAT
Only £284.98 inc VAT.
ORDER NOW
Arctic Cooling Freezer 13 High Performance CPU Cooler (Socket LGA775/1156/1366/939/AM2/AM2+) @ £23.49 inc VAT
Following the footsteps of the renowned Freezer 7 Pro Rev.2., the Freezer 13 carries on the legacy of providing efficient and low noise CPU cooling solution for enthusiasts. Featuring a whisper-quiet 92 mm PWM fan, aluminum fins with heatpipes, the Freezer 13 can perform its duties with any high-performance CPU.
- Heatsink Dimension: 123mm x 96mm x 130mm (L x W x H)
- Heatsink Material: Aluminum fins x 45, thickness 0.5mm
- Fan: 92mm, 600 – 2000 RPM (controlled by PWM)
- Air Flow: 36.4 CFM
- Max. cooling capacity: 200 Watts
- Bearing type: Fluid Dynamic Bearing
- Weight: 695g
- Compatibility: Intel 775/1156/1366 AMD 939/AM2/AM2+/AM3
Was £27.99 Inc. VAT
Only £23.49 inc VAT.
ORDER NOW
Gigabyte GA-P55-USB3 Intel P55 (Socket 1156) DDR3 Motherboard @ £89.99 inc VAT
The Gigabyte USB 3.0 series motherboards support the latest generation SuperSpeed USB 3.0 technology made possible through an onboard NEC uPD720200 host controller. With superfast transfer rates of up to 5Gbps, users are able to experience an almost a 10x improvement over USB 2.0. Additionally, backwards compatibility with USB 2.0 assures users of long term use of their legacy USB 2.0 devices. The onboard NEC SuperSpeed USB 3.0 technology also provides new power management features that include increased maximum bus power and device current draw to better accommodate power-hungry devices.
- CPU: Intel Core i7/Core i5 Processors (Socket LGA1156)
- Chipset: Intel P55 Express
- Memory: 4x DDR3 DIMM 2200 / 1333 / 1066 / 800 MHz (Max. 16GB) / Dual Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 2x PCIe 2.0 x16 Slots, 2x PCIe x1 Slots & 3x PCI Slots (Supports ATI CrossFireX Technology)
- Storage: 1x Floppy, 1x Ultra DMA 133/100/66 & 8x SATA 3Gb/s (RAID 0, 1, 5 and 10)
- LAN: RTL8111D Gigabit LAN
- Audio: ALC888 8-channel High Definition Audio CODEC
- 14x USB 2.0
- 2x USB 3.0/2.0
- 1x PS/2 COMBO (Keyboard & Mouse)
- 1x S/PDIF Out (Optical)
- 1x S/PDIF Out (Coaxial)
Was £99.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Asus P5QPL-AM Intel G41 (Socket 775) DDR2 microATX Motherboard @ £33.98 inc VAT
The P5QPL-AM is built using the Micro ATX form factor, supporting a range of Intel processors including the Core 2 Quad and Core 2 Duo processors with 1333/1066/800MHz system bus in the LGA775 package and dual channel DDR2 800/667MHz SDRAM memory. It offers legacy and premium features such as parallel port, Intel HD Video playback, Intel High Definition Audio and integrated 10/100/1000 network connection to enrich your multimedia experience.
- Intel G41 + ICH7 Chipset
- FSB 1333/1066/800MHz
- Integrated Intel Graphics Media Accelerator (Intel GMA X4500)
- Supports Microsoft DirectX 10 & OpenGL 2.1
- 4x SATA 3Gb/s ports
- 1x PCIe x16
- 1x PCIe x1
- 2x PCI
- ASUS MyLogo 2
- ASUS EZ Flash 2
- ASUS CrashFree BIOS 3
- ASUS Q-Fan
- Turbo Key
- AI NET2
- V-Core Solid Capacitors
- Warranty: 2 years
Was £39.99 Inc. VAT
Only £33.98 inc VAT.
ORDER NOW
Foxconn A7DA-S 3.0 AMD 790GX (Socket AM3) DDR3 Motherboard @ £49.98 inc VAT
Part of the Performance series of motherboards, the A7DA-S 3.0 offers enhanced connectivity and entertainment capability, backed-up by high-performance features and components. Based on the AMD® 790GX and SB750 chipset with an advanced DirectX 10 graphics engine with AMD UVD technology. UVD supports Blue-Ray and HD-DVD content, whilst offloading power and processor-intensive video decoding from the CPU to the graphics core. Side port memory is supported and does increase performance a good deal. Supporting AMD the latest Phenom™II processors with HT3.0 technology.and supports Dual DDR3 1333MHz memory for better overall system performance.2* PCIe Gen2.0 x16 slots are provided, enabling support for ATI CrossFireX™ technology and ATI™ Hybrid graphics technology - which boosts your system performance by enabling the ability for both discrete graphics and integrated graphics to render simultaneously. The A7DA-S 3.0 is designed for supporting Foxconn unique green(GSM) technology.
- AMD Phenom™II processor, Socket AM3
- Supports Socket AM3 with HT3.0 interface
- 5.2 GT/s HyperTransport™
- 128MB DDR3 1333 Side Port Memory onboard
- Dual channel DDR3 1333/1066/800 x 4 DIMMs, Max. 8GB
- 2x PCIe2.0 x16, 2x PCIe2.0 x1, 2x PCI
- 1x ATA133, 2x 1394a, 6x SATA II (one supports eSATA)
- 7.1 channel HDA, Realtek® ALC888-GR
- Gigabit LAN, Broadcom® BCM5784
- 12 USB 2.0 ports
- Warranty 3 years
Was £69.98 Inc. VAT
Only £49.98 inc VAT.
ORDER NOW
Gigabyte GA-H55M-UD2H Intel H55 (Socket 1156) DDR3 microATX Motherboard @ £62.08 inc VAT
This motherboard supports the latest Intel Lynnfield and Clarkdale processors in the LGA1156 package, which has memory and PCI Express controllers integrated to support dual-channel (4 DIMMs) DDR3 memory and PCI Express 2.0 16x lanes providing higher graphics performance. Moreover, Intel Clarkdale integrated Graphics Processing Unit (GPU) processors together with Intel H55 chipset deliver a whole new experience of the next generation VGA performance. It also provides separated 3D, 2D and Video Engines to execute different graphic control in hardware.
- CPU: Intel Core i7/Core i5/Core i3/Pentium Processors (Socket LGA1156)
- Chipset: Intel H55 Express
- Memory: 4x DDR3 DIMM 1666+(OC) / 1333 / 1066 MHz (Max. 16GB) / Dual Channel
- Expasion slots: 2x PCIe 2.0 x16 Slot & 2x PCI Slot (Supports ATI CrossFireX Technology)
- Storage: 1x Ultra DMA 133/100/66 & 5x SATA 3Gb/s & 1x eSATA 3Gb/s
- Audio: ALC889 8-channel High Definition Audio CODEC
- 2x IEEE 1394a
- 12x USB 2.0
- 1x DisplayPort
- 1x HDMI
- 1x DVI
- 1x D-SUB
- 2oz Copper PCB
- Smart6 (QuickBoot, QuickBoost, Recovery, DualBIOS, Recorder & TimeLock)
- Dynamic Energy Saver 2
Was £69.13 Inc. VAT
Only £62.08 inc VAT.
ORDER NOW
Asus P6X58D-E Intel X58 (Socket 1366) DDR3 Motherboard @ £139.99 inc VAT
This motherboard supports the latest Intel Core i7 processors in LGA1366 package with integrated memory controller to support 3-channel (6 DIMMs) DDR3 memory. The P6X58D-E breaks the boundaries to bring you the multi-GPU choice of either SLI or CrossFireX. The motherboard features a dedicated graphics engine on the most powerful Intel X58 platform to optimize PCIe allocation in multiple GPU configurations. Supporting next-generation Serial ATA (SATA) storage interface, this motherboard delivers up to 6.0Gb/s data transfer rates. Additionally, get enhanced scalability, faster data retrieval, double the bandwidth of current bus systems. Experience ultra-fast data transfers at 4.8Gbps with USB 3.0 - the latest connectivity standard. Built to connect easily with next generation components and peripherals, USB 3.0 transfers data 10X faster and is also backward compatible with USB 2.0 components. 16+2 phase power design, 16-phase for vCore and extra 2-phase for QPI/Memory controller inside CPU, can provide the highest power efficiency, and hence generates less heat to effectively enhance the overclocking capability.
- CPU: Intel Core i7 Processors (Socket LGA1366)
- Chipset: Intel X58 Express
- Memory: 6x DDR3 DIMM 2000(OC) / 1600 / 1333 / 1066 MHz (Max. 24GB) / Triple Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 3x PCIe 2.0 x16 Slots, 1x PCIe x1 Slots & 2x PCI Slots (Supports ATI CrossFireX & NVIDIA SLI Technology)
- Storage: 6x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 2x SATA 6Gb/s
- LAN: Marvell 88E8056 Gigabit LAN
- 8x USB 2.0
- 2x USB 3.0/2.0
- 2x IEEE 1394a
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
- 16+2 Phase Power Design
- TurboV
- MemOK!
- EPU
- Express Gate
- Fanless Design
- Stack Cool3+
- CrashFree BIOS 3
- EZ Flash 2
- MyLogo 2
Was £154.99 Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
Samsung SH-S223L/RSMN 22x DVD±RW SATA Lightscribe ReWriter (Beige/Black/Silver) - Retail @ £11.74 inc VAT
Samsung's 22x Serial SATA DVD Writer supports powerful over speed performance which allows writing with the high speed of 22x on a low cost 16x media and now includes the Lightscribe Labelling function.
Write Speed
- DVD-R: 22x
- DVD-R: 22x
- DVD-R DL: 12x
- DVD+R DL: 16x
- DVD+RW: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- CD-R:48x
- CD-RW: 4x
Read Speed
- DVD-R: 16x
- DVD+R: 16x
- DVD-R DL: 12x
- DVD+R DL: 12x
- DVD-RW: 12x
- DVD+RW: 12x
- DVD-RAM: 12x
- CD-R: 40x
- CD-RW: 40x
Was £15.26 Inc. VAT
Only £11.74 inc VAT.
ORDER NOW
Sony Optiarc AD-5260S 24x DVD±RW SATA ReWriter (Black) - OEM @ £11.74 inc VAT
The AD-5260S burns DVD+R/-R discs at amazing 24X speed, delivering a full 4.7GB DVD in 4 minutes and below Double/Dual layer discs are written at 12X max. Slot in Audio CD-Rs recorded by the AD-5260S, and enjoy the refined CD sound quality!
-Interface: S-ATA
Write Speed
- DVD-R: 24x
- DVD+R: 24x
- DVD-RW: 6x
- DVD+RW: 8x
- DVD-R DL: 12x
- DVD+R DL: 12x
- CD-R: 48x
- CD-RW: 32x
Read Speed
- DVD-R: 16x
- DVD-RW: 12x
- CD-R: 48x
- CD-RW: 40x
- CD-ROM: 48x
-Media supported DVD-ROM, DVD-R (DL), DVD-RW, DVD+R9, DVD+RW, CD-ROM, CD-R and CD-RW with 80mm and 120mm diameter
-Modes supported DVD-ROM, DVD-Video, CD-ROM, CD-ROM XA, CD-I Ready, CD-Bridge, PhotoCD, VideoCD, CD-DA, CD Extra, CD Text
Was £17.61 Inc. VAT
ORDER NOW
Asus Rampage II Extreme Intel X58 (Socket 1366) DDR3 Motherboard @ £179.99 inc VAT
The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in. In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers. This motherboard supports the latest Intel® Bloomfield processors in LGA1366 package which has memory controller integrated to support 3-channel (6 DIMMs) DDR3 memory. Support Intel(R) QuickPath Interconnect (QPI) with system bus up to 6.4GT/s and a max bandwidth of up to 25.6GB/s. Intel® Bloomfield processor is one of the most powerful and energy efficient CPU in the world. The Intel® X58 Express Chipset is the latest chipset designed to support latest Intel® Core™ i7 Processors and Intel’s next generation system interconnect interface, Intel® QuickPath Interconnect (QPI), providing improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. It also supports up to 36 PCI Express 2.0 lanes providing better graphics performance. SLI or CrossFireX? Fret no longer because with the ROG Rampage II Extreme, you’ll be able to run both multi-GPU setups. The board features SLI/CrossFire on Demand technology, supporting up to three graphics cards in a 3-Way SLI or CrossFireX configuration. Whichever path you take, you can be assured of jaw-dropping graphics at a level previously unseen. The motherboard supports DDR3 memory that features data transfer rates of 1800(O.C.)/1600(O.C.)/1333/1066 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The triple-channel DDR3 architecture triple the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 43.2 GB/s.
- Intel® Core™i7 Processor Ready
- Intel® X58/ICH10R
- Triple-channel, DDR3 1800(O.C) Support
- TweakIt
- ProbeIt
- Extreme Engine with ML Cap Design
- SLI/CrossFire On-demand
- SupremeFX X-Fi
- BIOS Flashback
Was £189.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Argon Extreme Intel Core i3 540 3.06GHz @ 4.20GHz Overclocked Bundle @ £229.98 inc VAT
Designed by experts the "Argon Extreme Intel Core i3 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.20GHz overclock has the processing power and speed to power through the latest games with ease. The "Argon Extreme Intel Core i3 Bundle" offers superb gaming performance at an excellent price.
Why You Should Buy This Bundle?
- A solid, optimised 4.20GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers unlimited bandwidth
Bundle Specification
- CPU: Intel Core i3 540 3.06GHz @ 4.20GHz
- Motherboard: Gigabyte GA-H55M-UD2H (Socket 1156) DDR3 Motherboard
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Artic Cooling Freezer 7 CPU Cooler
- Artic Silver 5 Thermal Compound
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £259.98 Inc. VAT
Only £229.98 inc VAT.
ORDER NOW
Argon AMD Athlon II X2 255 3.10GHz @ 3.70GHz Overclocked Bundle @ £179.97 inc VAT
Designed by experts the "Argon AMD Athlon II X2 255 Overclocked Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Argon II X2 AMD Athlon 255 Overclocked Bundle" offers you speed and silence in perfect combination.
- Prebuilt and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers fast load times
- Onboard graphics allows for 1080p output
- CPU: AMD Athlon II X2 255 Dual Core 3.10GHz @ 3.70GHz
- Motherboard: Foxconn A7DA-S 3.0 AMD 790GX (Socket AM3) DDR3 Motherboard
- RAM: Corsair XMS3 (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Freezer 7 Pro Rev 2 CPU Cooler
Service Package
Was £199.97 Inc. VAT
Only £179.97 inc VAT.
ORDER NOW
Krypton Crosshair AMD Phenom II X6 1055T 2.80GHz @ 3.80GHz Overclocked Bundle @ £349.99 inc VAT
Designed by experts the "Krypton AMD Crosshair Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 3.80GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
- A solid, optimised 3.80GHz overclock profile provides outstanding processing performance
- CPU: AMD Phenom II X6 1055T 2.80GHz @ 3.80GHz
- Motherboard: Asus Crosshair III Formula AMD 790FX (Socket AM3) DDR3 Motherboard
- Cooler: Corsair A50 CPU Cooler
Service Package
Was £369.98 Inc. VAT
Only £349.99 inc VAT.
ORDER NOW
Krypton Intel Core i7 950 3.06GHz @ 4.00GHz USB3/SATA 6Gb/s Overclocked Bundle - Gigabyte @ £553.99 inc VAT
Designed by experts the "Krypton Intel Core i7 950 Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 4.00GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
- A solid, optimised 4.00GHz overclock profile provides outstanding processing performance
- 6GB of Triple Channel DDR3 memory delivers unlimited bandwidth
- X58 Chipset provides SLI and Crossfire ready support for any GPU configuration
- SATA 6Gb/s and USB 3.0 compatible offering lightning fast transfer speeds
- CPU: Intel Core i7 950 3.06GHz @ 4.00GHz
- Motherboard: Gigabyte GA-X58A-UD3R (Socket 1366) DDR3 Motherboard
- RAM: Corsair XMS3 (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
- Artic Cooling MX-3 Thermal Compound
Service Package
Was £563.99 Inc. VAT
Only £553.99 inc VAT.
ORDER NOW
"Primo Drone" AMD Athlon II X2 Dual Core 250 3.00GHz DDR3 System @ £225.99 inc VAT
The "Primo Drone" offers the performance needed for home and business use at a low price. The AMD Athlon II X2 Dual Core 250 3.00GHz combined with 4GB of 1333MHz DDR3 RAM, offers a quick and easy multitasking experience.
Why You Should Buy This System?
- AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) offers multitasking performance.
- 500GB Seagate Barracuda hard drive gives a solid and reliable storage capacity.
- 4GB of 1333MHz DDR3 RAM allows for snappy and precise processes to be made.
System Specification
- Case: OcUK Hades Micro ATX case - Black
- Power Supply: OcUK Value 450W PSU
- CPU: AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3)
- Motherboard: Asus M4N68T-M LE NForce 630a (Socket AM2+/AM3) DDR3Motherboard
- RAM: OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel
- Hard Drive: Seagate Barracuda 500GB 16MB Cache
- Graphics Card: Onboard integrated NVIDIA GeForce 7025 GPU
- Sound: ALC662 6-channel High Definition Audio CODEC
- Optical Drive: LG GH22NS50 22x DVD±RW SATA ReWriter
Service Package
Is this System for You?
Compact, reliable and smart. The "Primo Drone" give you everything you need in a entry level home/business system.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
Was £245.99 Inc. VAT
Only £225.99 inc VAT.
ORDER NOW
"Titan Xenomorph" Intel Core i3 540 3.06GHz @ 4.20GHz Nvidia Edition DDR3 System @ £569.99 inc VAT
The "Titan Xenomorph" features a Intel i3 540 3.06GHz processor overclocked and guaranteed to a stable 4.20GHz, combined with a selection of high performance, handpicked components placed into an Antec 300 gaming case with Nvidia green fans to give it a unique look and feel. Experience a true DX11 experience and harness the power of PhysX and CUDA with the Nvidia GeForce GTX 400 Series. The additional front intake fans keep the system cool and quiet so that you can game all through the night with style.
- A guaranteed 4.20GHz performance for the price of 3.06GHz
- Choose from a selection of graphics cards to meet your performance needs
- Precision built and cabled by Overclockers UK expert technicians
- Case: Antec 300 Case with Nvidia Green case fans.
- Power Supply: Corsair CX 600W
- CPU: Intel Core i3 540 3.06GHz Clarkdale overclocked to 4.20GHz
- Motherboard: Gigabyte H55M-UD2H Intel H55 (Socket 1156) PCI-Express DDR3 Motherboard
- Cooler: Corsair H50 CPU Cooler
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
- Hard Drive: Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache
- Graphics Card: Nvidia 400 Series DX11 Compatible Graphics Cards
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
Featuring a 4.20GHz overclock and utilising the latest Nvidia GeForce Series of graphics cards, the "Titan Xenomorph" is a force to be reckoned with.
Was £599.99 Inc. VAT
Only £569.99 inc VAT.
ORDER NOW
"Titan Krypt" AMD Athlon II X4 640 3.00GHz Quad Core DDR3 System @ £420.61 inc VAT
The "Titan Krypt" features a AMD Athlon II X4 Quad Core 640 3.00GHz Processor, combined with a selection of high performance, handpicked components designed to meet your desire for the perfect gaming system.
Why Should You Buy This System?
- Includes the superb AMD Athlon II X4 640 3.00GHz Quad Core Processor
- 4GB of high performance gaming memory guarantees the smoothest possible experience when multitasking and ensures you never have a break in the action
- Case: Antec 300 Gaming Case
- CPU: AMD Athlon II X4 Quad Core 640 3.00GHz Processor
- Motherboard: Asus M4A78LT-M 760G (AM3) Motherboard
- Hard Drives: Seagate Barracuda 1TB SATA-II 16MB Cache
- Graphics Card: Choice of the latest DirectX 10 and 11 graphic cards
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: OcUK 22x DVD±RW SATA ReWriter (Black)
Service Package
If your after the latest in AMD technology then this system is for you. Based upon the 760G (AM3) chipset it offers full USB 3.0 support and SATA 6GB/sec ensuring your system is always up to date. Play and see games the way they are meant to be played.
Was £455.86 Inc. VAT
Only £420.61 inc VAT.
ORDER NOW
"Ultima Viper" Intel Core i7 950 3.06GHz @ 4.00GHz DDR3 System @ £889.36 inc VAT
The "Ultima Viper" features a Intel i7 950 3.06GHz processor overclocked and guaranteed to a stable 4.00GHz, combined with a selection of high performance, handpicked components designed to meet your desire for the perfect gaming system.
- A guaranteed 4.00GHz performance for the price of 3.06GHz
- 6GB of 1600MHz DDR3 Triple Channel memory allows faster loading of games and better multi-tasking
- Case: Antec 902 Ultimate Gaming Case - Black
- Power Supply: Corsair TX 650W ATX SLi Compliant Power Supply
- CPU: Intel Core i7 950 3.06GHz Overclocked to 4.00GHz
- Motherboard: Asus P6X58D-E Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
- Cooler: Corsair H70 CPU Cooler
- RAM: Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel
- Hard Drive: Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache
- Graphics Card: Choice of the latest graphics cards
- Sound: Realtek ALC889 7.1 Channel Sound (On-Board)
Service Package
Do you always want more? Do you want to be at the top of your game? Having the fastest system for a great gaming experience is now just a click away. This system is designed and built for gamers, by gamers.
Was £924.61 Inc. VAT
Only £889.36 inc VAT.
ORDER NOW
Belkin F5D8633UK4A 300Mbps Wireless N ADSL2+ Modem/Router @ £25.84 inc VAT
Connect your wired and wireless desktop computer and notebooks to your Belkin N Wireless Modem/Router to share your broadband internet access. Now you can quickly exchange documents, share resources, and distribute large video and music files throughout your network at a link rate of up to 300Mbps which can save you time.
Belkin's advanced security protects both your wireless and wired computers from hackers and intruders, providing you with the peace of mind you require for your security of your data and personal information. You can add up to 16 computers to your wireless network with additional notebook and desktop adapters.
- Data transfer rate of up to 300 Mbps
- Plug and Play Setup making it easy to setup your home network
- Ports: ADSL Phone Line - 10/100 LAN Port - 4
- Security Wi-Fi Security modes: WPA, WPA2-Personal, 64-bit/128-bit encryption and multiple SSID to ensure you're protected against viruses and hackers
- Backwards compatable with Wireless A/B/G/N receivers
- VPN Support: Allows you to access your network from any computer in the world.
Was £29.36 Inc. VAT
Only £25.84 inc VAT.
ORDER NOW
Microsoft Windows 7 Home Premium 64-Bit - OEM (GFC-00599) @ £76.36 inc VAT
Windows 7 Home Premium offers a rich, dynamic entertainment experience on your PC, making it easy to create a home network and share all of your favorite photos, videos, and music. You can even watch, pause, and rewind TV or record it to watch whenever and wherever you want.
- Record TV on your PC: Watch, pause, rewind, and record TV, movies, and other video content with Windows Media Center, updated to manage a single TV guide containing both standard and digital high definition TV shows.
- Personalise your desktop: Easily change backgrounds, window colours and sounds to reflect your personal style. You can even turn your desktop into a slide show of your favorite photos.
- Share files across the various PCs in your home: Use HomeGroup to connect your PCs running Windows 7 to a single printer. Specify exactly what you want to share from each PC with all the PCs in the HomeGroup.
- Pin any program to the taskbar: Any program is always just a click away - and you can rearrange the icons on the taskbar just by clicking and dragging.
- Stream music files on any network-connected device: Just open Windows Media Player, right-click on what you'd like to hear, select Play To, and you'll see a list of devices and PCs on which you can play your music.
- Find virtually anything on your PC - from documents to photos to e-mail: Just click on the Start button, and enter a word or few letters in the name or file you want into the search box, and you’ll get an organised list of results.
- Access recently used files with just two clicks: Right-click the relevant program icon (such as Word) on your taskbar and Jump List will show your most recent, frequently used, and pinned Word documents.
Was £82.24 Inc. VAT
Only £76.36 inc VAT.
ORDER NOW
Seagate Momentus XT 500GB Hybrid SATA-II 2.5" 7200RPM 32MB @ £96.34 inc VAT
nonl2br
Powerful, intelligent, affordable - solid-state hybrid drives deliver SSD-like performance without sacrificing storage capacity and affordability. <br><br>
- Adaptive Memory™ technology <br><br>
- 80% faster than traditional 7,200-RPM drives <br><br>
- Boot within seconds of a laptop with SSD <br><br>
- Work in any standard laptop with any OS <br><br>
- Seagate 5-year limited warranty <br><br>
The Seagate Momentus® XT solid state hybrid drive combines SSD-like performance with affordable high-capacity hard drive storage for laptops, external backup and small form factor desktop PCs. This drive is designed for all standard laptop PCs and is OS-, driver- and software-independent, making it easy to integrate and easy to use. <br><br>
The Momentus XT drive offers hybrid storage with Adaptive Memory technology, enabling the drive to deliver higher capacities up to 500GB and SSD-like performance. <br><br>
Adaptive Memory Technology <br><br>
Designed with high-performance core components on an innovative platform, the Momentus XTdrive consists of a 7200-RPM hard drive with 32MB of cache, 4GB of solid state SLC NAND flash storage, and Adaptive Memory self-learning technology. Adaptive Memory technology intelligently monitors frequently used applications and data fi les, then places them into the solid
state portion of the drive so they can be quickly recalled. Adaptive Memory technology enables the drive to tailor its performance to the user.Whether you are gaming, editing digital media or
crunching numbers, the performance is optimized and ready for your next move. <br><br>
Key Specifications <br><br>
- 500GB, 320GB and 250GB hard drive capacity options <br><br>
- 4GB SLC NAND solid-state memory <br><br>
- 7,200-RPM spindle speed <br><br>
- 32MB of drive-level cache <br><br>
- SATA 3-Gb/s interface with Native Command Queuing <br><br>
Best for <br><br>
- High-end laptops and workstations <br><br>
- High-performance gamer laptops <br><br>
- Fast external enclosures: USB 3.0, eSATA <br><br>
- Small form factor PCs <br><br>
- High performance Desktop Storage <br><br>
<br><br>
<<object width="640" height="385"><param name="movie" value="
"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Was £99.99 Inc. VAT
Only £96.34 inc VAT.
ORDER NOW
Seagate Barracuda LP 1.5TB SATA-II 32MB Cache - OEM 1yr Warranty (ST31500541AS) @ £45.81 inc VAT
Combining proven components and state-of-the-art technology, the Seagate Barracuda 7200.11 drive - the 11th generation of this award-winning desktop hard drive family - delivers high-performing, eco-friendly digital storage. Designed with industry-leading acoustics and power levels, and award-winning Seagate PMR technology, the Barracuda 7200.11 drive offers the ideal combination of world-class technology and lowest total cost of ownership.
- Capacity: 1.5TB
- Cache: 32MB
- Spin Speed: 5900RPM
- Seek Time: 8.5ms
- Warranty: 1 Year (This is a clean pull from an un-used none O.S. PC, these drives have been tested and used upto 150hrs)
Was £47.98 Inc. VAT
Only £45.81 inc VAT.
ORDER NOW
Seagate Barracuda 7200.11 1.5TB SATA-II 32MB Cache - OEM 1yr Warranty (ST31500341AS) @ £46.40 inc VAT
- Capacity: 1.5TB
- Cache: 32MB
- Spin Speed: 7200RPM
- Seek Time: 8.5ms
- Warranty: 1 Year
Was £49.98 Inc. VAT
Only £46.40 inc VAT.
ORDER NOW
Hitachi Deskstar 7K1000.C 1TB SATA-II 32MB Cache - Retail @ £39.99 inc VAT
The Deskstar 7K1000.C hard drive is a 7200RPM 3.5" hard drive that provides an exceptional blend of power efficiency and performance, making it an ideal solution for power friendly consumer and commercial desktop computers. This third-generation 1TB hard drive from Hitachi boosts media transfer rate performance by as much as 13% over its predecessor. Leveraging eighth-generation power management technology, as well as power-saving HiVERT innovations pioneered on the popular 2.5" line of notebook hard drives from Hitachi, this new desktop drive provides up to 18% idle power savings over the previous model, delivering best-in-class power management and thermal emissions.
- Capacity: 1TB
- Cache: 32MB
- Warranty: 3 Years
- Retail package: Perfect for Christmas.
Was £45.99 Inc. VAT
ORDER NOW
Western Digital Caviar Green 2TB SATA-II 64MB Cache - OEM (WD20EARS) @ £75.99 inc VAT
WD Caviar Green SATA hard drives reduce power consumption by up to 40% and offer best-in-class acoustics and operating temperature. Based on WD's exclusive GreenPower technology, these drives are designed to deliver power savings as the primary attribute. As hard drive capacities increase, the power required to run those drives increases as well. WD Caviar Green drives make it possible for energy-conscious customers to build systems with higher capacities and the right balance of system performance, ensured reliability, and energy conservation. They are ideal for PCs, external storage and other devices that require lower power consumption and cool, quiet operation.
- Capacity: 2TB
- Cache: 64MB
- Spin Speed: IntelliPower
- Warranty: 3 Years
Was £84.99 Inc. VAT
Only £75.99 inc VAT.
ORDER NOW
Samsung G3 Station 1.5 TB External hard drive @ £64.99 inc VAT
Package Contents
- Model: G3 Station external hard drive
- Accessory: AC adapter and power cord,USB cable (120cm)
- Capacity: 1.5 TB
- Operating Systems: Windows, Mac (1)
- Color: Cobalt Black
- Interface: USB 2.0
- Data Transfer Rate: 480Mbps
- Temperature / Operating: 5C to 40C
- Temperature / Non-operating: 20C to 65C
Physical Dimensions
- Height ( Max ): 133.8 mm (5.27 inches)
- Width: 47.0 mm (1.85 inches)
- Length: 180.6 mm (7.11 inches)
- Weight (Max): 0.89 Kg (1.96 pounds)
Was £79.99 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
Iomega Prestige 1TB 2.5" Portable Compact USB Hard Drive @ £84.99 inc VAT
At just over 110 millimeters long, the super-compact, lightweight Iomega Prestige Portable Hard Drive, Compact Edition is perfect to carry in your pocket, backpack or laptop bag. It requires no external power supply – just plug it in and go. And with the Drop Shock feature, the Prestige Portable Hard Drive is rugged enough to safely store data for travel environments. Iomega Protection Suite includes Trend Micro Internet Security software (12 month free subscription), EMC Retrospect Express Backup software, Iomega QuikProtect, and MozyHome Online Backup service (2GB free) to protect your data and your computer (software available via easy download). This is a great travel companion that lets you take your files, photos and music anywhere.
- Device Type: Hard drive - external
- Capacity: 1TB
- Interface Type: Hi-Speed USB
- Power Source: USB bus
- Data Transfer Rate: 480 Mbps
- Weight: 172 g
- Dimensions: 8 cm x 11 cm x 1.6 cm
- Warranty: 3 years
- OS Required: Microsoft Windows 7, Apple MacOS X 10.4.x - 10.6.x, Microsoft Windows Vista / 2000 / XP
Was £88.99 Inc. VAT
Only £84.99 inc VAT.
ORDER NOW
Logitech Z-5500 THX Certified 5.1 Speaker System (970115-0120) @ £214.98 inc VAT
Many call the Z-5500 Digital speakers the best multimedia system ever. 505-watt RMS and a deep note 25.4 cm (10") subwoofer deliver thundering power, THX-certified, high fidelity, theatre-quality sound. You can simultaneously connect up to 6 audio sources (PCs, video game consoles and DVD/CD/portable music players). Innovative satellite design with removable cloth grilles and rotating pedestals allow desk placement or wall-mounting, so you can transform any room into a home theatre.
- 505w RMS, THX-certified, integrated hardware decoding for true 5.1 digital sound
- Built-in hardware decoding for Dolby Digital & DTS - the only way to get true 5.1 digital sound from PlayStation 2, Xbox, and most DVD players
- 25.4 cm (10”) high-excursion subwoofer driver with flared bass port pounds out powerful distortion-free bass
- Support for 96 kHz / 24 bit digital audio streams for studio-quality sound
- Revolutionary driver technology: polished aluminium phase plug satellites combine two drivers into one: the clarity of a tweeter with the richness and fullness of a separate mid-range
- Dolby Pro Logic II creates realistic 5.1 surround sound from stereo music, movies & games
- Connect to multiple sources: simultaneously connect 6 audio sources including PCs, video game consoles, and DVD, CD & portable music players
- 6 channel direct input can be used as 3 separate stereo inputs
- Digital equalisation actively adjusts frequency response in real time for the cleanest, most accurate sound reproduction
- Innovative satellite design: Cloth grilles are removable for a pro-audio look. Pedestals rotate for easy wall mounting or desk placement. Centre channel can be mounted on wall, above or below monitor
- Wireless remote control: great for use with home theatres and video game consoles
Was £239.99 Inc. VAT
Only £214.98 inc VAT.
ORDER NOW
Altec Expressionist Ultra MX6021 2.1 Speaker System - Black @ £104.99 inc VAT
Put yourself in the heart of the action with this 3-piece, 200 watt powerhouse. The Expressionist Ultra is the ideal system for taking it all in—music, games and movies. You get exhilarating waves of sound coming at you from five digital amplifiers powering five separate drivers. From a long-throw 6.5-inch subwoofer that reproduces the lowest bass to the precision-matched 1-inch neodymium high-frequency tweeters, this is one serious audio system that can keep pace in the most demanding sonic environments. Connect additional devices (MP3, TV, game console, DVD player, etc.) or plug in your headphones.
- Two 75 mm mid-range and two 22 mm high-frequency neodymium drivers
- 165 mm long-throw woofer
- Sound Pressure Level (SPL): 106 dB
- Total Continuous Power: 200 Watts RMS
- Midrange driver: 33 Watts per Channel @ 4 ohms @ 10% THD @ 150 Hz – 2.5 kHz
- Tweeter: 33 Watts per Channel @ 4 ohms @ 10% THD @ 2.5 kHz – 20 kHz
- Subwoofer: 68 Watts @ 8 ohms @ 10 % THD @ 40 Hz – 180 Hz Single Channel Loaded
- System Response: 40 Hz – 20 kHz (-10 dB)
- Signal to Noise Ratio @ 1 kHz input: greater than 75 dB
- Subwoofer Dimensions: 260mm (W) x 382mm (D) x 400mm (H)
- Satellite Dimensions: 135mm (W) x 156mm (D) x 220mm (H)
Was £114.99 Inc. VAT
Only £104.99 inc VAT.
ORDER NOW
Creative HS-400 Headset (51MZ0235AA007) @ £15.99 inc VAT
The HS-400 headset with noise-cancelling microphone is the right choice for internet voice applications or gaming. It delivers great audio over its headphones, for enhanced gaming pleasure, while users who demand the power of broadband telephony or voice conferencing will appreciate the advanced microphone, which automatically cancels-out background noise and has a rotary design which ensures a comfortable fit. It can also be detached easily when required. Lightweight and comfortable, the HS400 combines style, features and performance.
- Microphone can be detached for gaming and audio use.
- Rotary design makes microphone exceptionally comfortable.
- 30mm Neodymium magnet drivers give good results in gaming and audio.
- Oxygen-free copper cable for enhanced frequency response.
- Gold-plated stereo miniplugs for better connections.
- Stylish design stays comfortable for hours.
Was £16.99 Inc. VAT
Only £15.99 inc VAT.
ORDER NOW
Sharkoon X-Tatic Digital V3 Dolby Digital 5.1 Gaming Headset @ £111.99 inc VAT
Based on the same technology and build quality as its well known predecessor, we introduce the newest edition of the extremely popular X-Tatic. This high-quality headset features four speakers per earpiece and volume controls built into the cable. Through the included Sound Control Unit, the X-Tatic Digital can connect to the optical output of a game console (PS2, PS3, Xbox or Xbox 360), a PC, DVD player or other HiFi device and immediately delivers high-quality sound to listeners. The Sound Control Unit outputs analog Dolby Digital and Dolby ProLogic signals, and supports a second X-Tatic headset. With the newly developed microphone, the chat functions of the PS3 and the Xbox 360 are also supported. The ergonomic construction of the headset includes soft ear pieces and a plush headband, making the headset comfortable to wear even for long sessions.
Features:
- 5.1 channel headset
- 8 speakers (4 in each earpiece)
- Digital, in-line volume control
- High end amplifier
- Independent, illuminated volume adjustment for each channel and master volume
- Detachable microphone with QuickOn connection
Features (SCU):
- Supports Dolby® Digital 2.0, Dolby® Digital 5.1 and Dolby® Pro Logic®
- Supports the chat function of PS3®, Xbox® and Xbox® 360
- Dynamic Range Control
Specifications:
- Center speaker: 2 x 27 mm
- Front speaker: 2 x 30 mm
- Rear speaker: 2 x 30 mm
- Subwoofer: 2 x 40 mm
- Impedance: 32 Ohm
- Microphone: 6 x 5 mm (L x W) / unidirectional
- Cable Length: 360 cm
- Connection: 1 x 9-pin analogue plug
Specifications (SCU):
- Digital optical input (S/PDIF)
- 2 analogue audio outputs for the X-Tatic headset
- 3 analogue 3.5 mm audio outputs (front, rear, center / subwoofer)
- 1 microphone connector for PS3 (USB A -> USB B)
- 1 power connector
- Dimensions: 15 x 122 x 56 mm (H x L x W)
- Weight: 110 g
Compatibility:
- PC / MAC / other sources: analogue input (via cable adapter)
Compatibility (SCU):
- Xbox® / Xbox® 360: optical input
- PS2® / PS3®: optical input / USB microphone connection
- PC / MAC: optical input / analogue or USB microphone input
- DVD / other sources: optical input
Package content:
- X-Tatic Digital 5.1 headset
- Microphone
- Cable adapter (9-pin analogue plug > 3 x 3.5 mm)
- X-Tatic Sound Control Unit
- USB microphone cable for PS3 and PC
- Power adapter
- Microphone connection cable for Xbox 360 (2.5 mm jack > 2.5 mm jack)
- Optical connection cable (S/PDIF)
- Manual (8 languages)
Was £119.99 Inc. VAT
Only £111.99 inc VAT.
ORDER NOW
What are them Iiyama prolight 26 inch monitors like, any good?
