For everybody's info it's a Mercielago. And yes, Lamborghini say the clutch will last between 6000 and 10,000 miles with normal driving or less if driven "hard". In my bosses case that normally equates to around 5,000 miles but he once did one and a full set of tyres in 3,000 miles.
The Lambo main dealer once told me they had seen one go in only 600 miles but he was a really bad driver
Oem "genuine" clutches can be found for around £3,000 on the internet, main and specialist dealer are more expensive plus fitting.
I've just pulled the car file and standard clutch with fitting is £6,000. A service every 7,500 miles is a grand. Brake discs are £2,000 a wheel if needed.
Rear tyres are £700 each, fronts are £300 so £2,000 for a full set.
Okay, I was a bit off with £10,000 although it always seems to need other stuff doing like brake pads and he tends to get it serviced as well while it's there but basically a clutch and tyres is only £8,000, not £10,000 as previously stated.
My point still stands though.
I had addumed that he would have known this before he sent his watch off, it'd take about 5 minutes to ask in his jewellery shop to look up how much they are.
