- 27 Feb 2006
- Normanton
I'm having some problems with a PC i've built with a HIS ATI 6850 card in it.
This is the complete spec:
HIS ATI Radeon HD 6850 1024MB GDDR5 PCI-Express Graphics Card
Intel Core i5 760 2.80GHz (Lynnfield) (Socket LGA1156)
Asus P7P55D-E Intel P55 (Socket 1156) DDR3 Motherboard
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
Samsung SpinPoint F3 1TB SATA-II 32MB Cache
Antec High Current Gamer 520W Power Supply
The problem seems to be the graphics card or the graphics drivers.
I'm running Windows 7 64bit and everything seems to work fine on the desktop if using the inbuilt windows drivers the problems start with the ATI drivers.
If I install the ATI drivers (tried the latest Catalyst 10.10e versions aswel as old versions and even the hotfix version) but in all cases I get random things happening.
I have tried doing a clean install of Windows but get the same problems as soon as I put the ATI drivers on, do you think my card is faulty or is there some conflict I might be missing
Thanks
Sometimes the PC will not even boot up its gets as far as loading the desktop and then just hangs on a black screen until you manually reboot it.
Sometimes its gets to the desktop and is all fuzzy and I have to reboot again.
If It gets to the desktop ok its then fine on the desktop and just in 2d mode eg web browsing etc.
If I try to load a game up eg Medal of Honour I get things like on the Menu of the game the screen splits into 2 screens or goes fuzzy straight away and I have to reboot.
Thanks
