nvidia 6200 le on tv
Are you using the svideo/tv-out to connect it to the TV? I have an 6200 LE that I use to connect to my old TV but I just connect it to the scart red/white/yellow inputs on the TV, use an svideo cable from the card to the yellow port on the TV and a RCA (red/white ports) to headphone style jack plugged into the speaker output on the PC.
Either way my card only just handles DVD playback on standard definition, don't know if it would be up to HD playback (mine's the 64MB version though).
I could be wrong but I think only amd have audio through hdmi on their cards. You would need to maybe have the speakers coming though your mobo or soundcard
all cards have sound through hdmi. this is a old card and does not have hdmi
ive got my computer on a tv through hdmi all working fine and ive done it years ago with older card you was years and dont have a clue how to do it now. and back then i didnt need sound used a amp and speakers. so at the moment ive not got it plugged in at all.
ill have to get the same as what you are using. or are there any adaptors i can use to make it easyer.
also what drivers are you on. sometime you get problems with new drivers on old cards
