Regarding 8 pin PCI-E connectors
8 Dec 2010
Hi, I was planing on ordering either a 6970 or 580 on the 15th once I see how the new ATI cards perform but I'am unsure if I will need to order a new psu. Currently I have an Enermax Galaxy 1000w psu that I purchased in 2006 to run two 8800 GTX's in SLI. It only has 4x 6 pin pci-e connectors, I purchased it just before they released them with 8pin connectors which was quite annoying. Anyway, long story short, can I get away with using 6 to 8 pin connectors with this psu or will I need to purchase a new one?
Thanks in advance for any help
Edit: Maybe should have posted this in the power supply section, sorry
contact enermax who will sort you out with a new cable with 8 pins they just have an adaptor built in on those anyways.
Well I haven't tried it gaming but I had exactly the same issue and brought 2 (keep a spare) of the convertors from ocuk - I hooked one up tonight to connect a gtx280 in my old pc with the enermax 1000w and it booted into linux fine so my experience is that it works.
Ive done extensive research on this and this simply isnt an option.
A 6 pin connector only provides 75w whereas an 8 pin provides 150.
Some people were suggesting 2 x 6 pin to 8 pin adapters, but they're rarer than unicorns, I cannot find them anywhere.
And the manufacturers (both ati and nvidia) for some reason specifically say they are not for long term use anyway.
I may even just get a 6950 if it has two 6 pin adapters, I don't really want to shell out for a new PSU either.
If you look at an 8 pin adaptor compared to a 6 pin, there is 2 extra black cables. Now, from my understanding, the yellow cables provide the power, and the black are grounds. Meaning a 6-pin has 3 power and 3 ground, whereas an 8-pin has 3 power and 5 ground.
I'm purely basing this off my psu which has 2 6+2 pin cables
I don't know, but this sounds like it makes a lot of sense to me.
Why would Nvidia/ATI start putting 8-pin connectors on high end graphics cards just to add extra ground pins and cause a number of PSU to become out of date? As far as I know neither ATI or Nvidia make PSUs, so it's not like they're trying to encourage sales.
New cards needing extra power makes more sense to me.
This is true, but the resistence drops off with more grounding and it can supply more power, but if its a 6+2 its built for it.
If it's a 6 it isn't, and is not recommended by ati and nvidia.
Oh and btw, this forum wont give you a definative answer, most people are just interested in arguing ATI vs. Nvidia, tech questions are frowned upon.
This is the Enermax cable you need
http://goods.us.marketgid.com/goods/1506/48717/
Am using one these on my Enermax 720w PSU...
It plugs into two of your PSU 6 pin PCI-E sockets to make one 8 pin PCI-E
I think your card will come with a molex to 8 pin converter. once the cards come out, check out some unboxing vids on youtube and see what you get with each
