Hi All
Since I broke my old 15" Acer laptop, Im after something a little more portable. I do a lot of nightshifts at work, so having something i can move easily between home and work would be good.
Also all i do nowadays is browse the web, check emails and play the odd movie, so i dont need anything top of the range.
Been looking at some netbooks, as i dont really need a cd drive either. The current ones seem to feature an Intel Atom N450 / 1gb Ram / 160gb HDD.
This (I think) would be ideal for what I want to do, but im not sure of the best netbook to go for. Ive seen an Emachines eM350 for £179.99 + 15% back with Quidco, so i thought this would be pretty good. Would ideally like to upgrade RAM to 2gb straight away too.
Can anyone comment on any of these netbooks. Would they be ok for basic browsing / email checking as well as watching the odd movie at work on nights?
There seems to be a shed load of these netbooks, all with pretty much the same spec, so im a bit lost which one to go for. Ideally, the less $$ spent, the better
Cheers
James
Cheers
James
