If prime bluescreens with anything lower then 1.25v set in the bios, but is stable with it set at 1.25v, then leave it at 1.25v.
The temps are fine, the idle is'nt brilliant but its not the worst iv seen either, the load temps are spot on for that cooler, so again no need to worry.
For comparison i idle in the mid 30's, and load up low to mid 60's, but i am on custom water, which is a lot better then the H70, and as you can see my idle is'nt spectacular, so no need to worry.
Set the bios volts to what u know to be stable, leave it at that, regardless of what cpu-z reads it at, aslong as its stable there is no need to worry.
