It looks when zooming like it's against a 295 gtx ?
I think your right especially since its showing 2.5 times the performance!
We could only dream that was against a gtx580 or even gtx480.
My analysis of all the reviews
Going off these 3dMark feature scores:
http://h-5.abload.de/img/69704mxh.jpg
The 6970 trounces the 5870 in everything, except Perlin Noise. Taking a look at Perlin Noise, which is a score reflecting shader power, we get:
5870: 175.42
6970: 146.02
Thus, 6970 is just 83.24% of the 5870's power in shaders. Now why is this significant?
As I wrote before, 5870 is VLIW-5 which is (w,x,y,z,t) where t is the transcendental unit. 6970 is now VLIW-4 which is (w,x,y,z) with 3 of the 4 shaders being used to calculate a transcendental. Now, why the big gap in Perlin Noise if VLIW-4 Cayman has 384 SIMDs and Cypress has 320 SIMDs?
Well first, 1536 is 96% of the 1600 shaders that Cypress has assuming all shaders are firing. If you factor in clocks, it's near exactly 100% of the 1600 shaders. However, that doesn't account for the 83% gap. Two possibilities:
a) The VLIW-4 compiler isn't doing as great a job yet, in which case drivers and optimizations may improve performance
or
b) 3dMark uses a lot of transcendentals, and hence Cayman isn't able to take advantage of the complex t-unit and is getting a performance decrease
So either way you look at it, the 6970 still has room for improvement with regards to 3dMark by improving the compiler and/or optimizing the 3dMark code for VLIW-4. Thus, at this time, 3dMark is not very indicative of actual in game 6970 performance.
(Besides, look at 5870 scores in Vantage at release and today... it's a whopping increase over a year of driver optimizations for a synthetic. Cayman should get even more seeing as how it is a different architecture)
So what's all this mean?
Well, I've been saying it for some time now, but I can see in-game performance putting the 6970 ~GTX 580 levels and the 6950 ~GTX570 levels. The key is that the 69xx improvement over Cypress will range greatly - and hence your perspective of how good the card is may differ.
One of the key things from the release of the GTX 480 and now 580 is that in some games, Nvidia has a whopping lead, and in others, the 5870 barely trails or even takes the lead. That's because Fermi's architecture enabled it to take advantage of certain games far better than the 5870 (esp. in some DX11 tessellation), whereas in others, the 5870's pure shader and texturing advantages bring it close.
However, this creates a wide variation in performance figures - some say Cypress trails only 15%, others say it trails 30%, etc. from the 480. What will be interesting to see is how "stable" Cayman performs relative to the GTX 580/570 - in other words, in games where Cypress trails heavily, does Cayman get a considerable boost over Cypress showing that Cayman is truly different from Cypress? We've seen from the Stalker benchmark, Cayman does get a 33% boost over Cypress so it's quite possible.
IMO this is what we'll see:
6970 will be anywhere from 10 to 50% faster than the 5870 based upon the game - in heavily tessellated games the lead should increase, in games with heavy shaders and little tessellation the lead is probably lower. 6970 should be close though probably trail to the GTX 580 in quite a few games overall though, and show less variation in performance relative to the 580 than the 5870 did. Likewise, in situations were CF doesn't scale well and/or tessellation is heavier (where the 5870 is weak), the 6970 might be very close to the 5970 but in other games, it will trail heavily.
In other words, my theory is that games where Cayman barely improves on 5870 are games with low-to-none tessellation and are heavily shader bound. These will also be games where the 5870 is really really close to the 480/580. Games where Cayman pulls far ahead of 5870 are games with higher levels of tessellation and/or less shader bound. DX11 titles and titles using heavy DXCompute features as well.
That's my assessment of the situation, and why so many people were giving doom and gloom when certain benchmarks were showing Cayman barely edging Cypress (3dMark and some other games), whereas in other benchmarks (such as Unigine Heaven, ComputeMark, Stalker etc.), the 6970 seems to beat the 5870 handily (and often gets close to the 5970).
Stalker COP:
Metro2033:
http://www.hardwareluxx.de/community/15873506-post1363.html
What'll be interesting to see is what games the reviewers use to compare. If they use games that are heavily 5870 favored, Cayman might not look great - however, if they show games where the 5870 struggled and 480/580 excelled, its possible Cayman looks amazing. Of course, this will show who's biased to who...
TL;dr - 3dMark and other benches are optimized for VLIW-5, and VLIW-4 isn't optimized yet, and so 3dMark isnt representative of Cayman performance yet. Where Cayman will shine and probably pull ahead is in DX11 games where DirectCompute and Tessellation is necessary. Ultimately, the suite/games tested will determine whether the 6970 looks like a big improvement. When compared to the 5870, it will probably show small improvement in games where shaders are heavy. In games where more TMUs and/or tessellation are required, 6970 pulls ahead. What's most important though is comparing it to the 480/580/570 and seeing if it is a more consistent performer relative to those cards than the 5870.
Oh and Antilles will be a beast
Just seem's real bizarre that they would just make the same improvements they made with 68xx (efficiency changes for shaders), improve the tessellator (the buffer increased?) and not actually actively try to improve performance levels above the 5870 significantly.
I don't think AMD relying on a dual card solution to solve this issue is a smart move, in fact I think it's bloody foolish IF they have gone down this path.
I'm not 'pro' AMD, but it is disappointing, I really hope for them that in two days time they actually have a decent single card on the table. I'm struggling to believe they haven't frankly.
That being said, AMD has a pretty clear progression where they're going - the only question is whether this is AMD's own doing, or Nvidia's, or both:
3870 - 55nm - 192mm^2 - 70% of 9800GTX
4870 - 55nm - 256mm^2 - 80% of GTX280
5870 - 40nm - 334mm^2 - 85% of GTX480
6970 - 40nm - 389mm^2 - ??% of GTX580
If the ?? is 90-95, that's the closest AMD has been in a long while, and is quite an engineering feat for a < 400mm^2, not to mention that it's only a 15% increase to decrease the performance gap, rather than the 30% jumps required by the previous 3 cards
IF this performance is correct where does this leave the 6950, that could be the card to get and overclock if it comes in well cheaper than the 6970. Still does not make sense the small jump in performance we are seeing here, I mean the 5870 was on the 480's heels performance wise and the 6970 is basically on par with a 480 if these results are correct.
If the 6970 is even closer to the 580 than the 5870 was to the 480, Antilles/6990 is probably absurd overkill.
^^ Looks like another fake.
..apart fromt he Micro Stutter, the waiting for updated drivers to play your newest game and power / noise and quirky in-game glitches of course.6990 will be slaughter, and bloodbath to 580 and anything else nvidia might pull up of their hat which isnt likely due to the design choices they made with fermi.
Hell even 6850 crossfire totally rocks.
Yeah.. quite amazingly so.
Over 200% scaling in xfire. Awesome.....
