Under hard acceleration, if I let go of the wheel, the car pulls strongly to the left. With no throttle, it stays straight if you let go of the wheel. Also stays straight if you hold it straight, but the wheel is trying to turn. More acceleration = more severe pull. Speed makes no difference, only amount of throttle.
What could cause this? I initially assumed geo but why would it only happen under acceleration? Surely not torque steer? Plant the throttle in 6th at 70mph and it still does it.
Tracking is fine, will do a full geo check asap, but as I said, surely anything geo related would make it pull left regardless of throttle input
Car is a Lupo GTI, on height/damping adjustable Koni coilovers. Recently I have replaced the wishbones and ball joints, but this problem has come on more recently.
Thanks
Thanks
