good stuff, but ....
is it me or is PS3 really slow for internet connections? they need to update their browser it is horrible to surf or stream on it
PS my ps3 is hooked via ethernet to router, same as my comp but speed is defo not the same. streaming is choppy, low quality and buggy imo, whereas it's great on pc
Yeah I agree, when I'm hard wired into my Desktop I get 37mb down and 8mb up. When I'm hard wired into my PS3 I get no more than 18mb down and 4mb up, it's like the adapter can't fully output my connection speed.
Ah really?
Bummer. That's why I use 4OD.
But I guess the majority of it is on the 4OD Youtube page anyway.
There's a front page of the ones that are just in of which there's only about 12 shows, but on the left hand side there's a full A to Z of TV shows with plenty of choice.
Awwww yeeaaaaah![]()
The adapter is fine, it's even gigabit (1000mb) capable.
I've personally never had any issues with the networking on the PS3 and generally find it very competent, I can even stream 1080p contact with DTS fine via wi-fi using the PS3 Media Server, and downloading always max's out my connection.
I can only assume that some ISP's don't fully open the ports for PSN but if you test your connection and have nat type 2 you should be fine.
Its does support Flash but not the most up-to-date version which is why some sites dont work. Im sure a while ago ITV Player was using Silverlight and not Flash anyway...This might be a silly question but why not simply support Flash and then they do't have to add every video streaming website individually. Seems retarded. Suerly the PS3/360 have teh powah.
Did they manually add TVcatchup or what cos as said that works(ed).
