Got a bit of an ongoing issue with some aluminium crank and alternator pulleys I have fitted to my Saxo VTS.
To cut a long story short: the belt makes a chirping noise at idle once warmed up, and disappears when you put some revs on the engine. Misting the belt with water stops the squeaking temporarily - it returns when it dries out. Fitting a new belt stops any squeaking until the belt gets wet then dries out. I've tried belt dressing spray and that only keeps the belt quiet for a few weeks.
Pulley alignment and the belt tension is fine. The tensioner and alternator bearings are also ok. The pulleys are made to a very high standard by a well known competition engine builder. I was convinced something was wrong with the original set of pulleys I had, so the supplier kindly sent me a brand new set with a new Goodyear V belt. Fitted those and I didn't hear a peep for around 2-3 months. For the majority of that time, the belt felt quite loose to the touch (obviously stretched as it wore in). Now the squeaking has returned - exactly the same as before.
The supplier has sold hundreds of kits and doesn't know of anyone else who's had problems with squeaking. I know of one other person who did have problems with squeaking - he fitted a smaller belt (the one supplied in the kit is a 4PK725) and that apparently solved the problem. I've tried tightening the 4PK725 as much as I can - belt feels too tight imo, and the squeaking is still there.
I'm slightly tempted to try a different brand of V belt. I tried a Gates belt in the past and it kept jumping around on the crank pulley regardless of tension - it didn't want to sit in the pulley for some reason. The only other belts I've tried have been Goodyear.
Any ideas? I am totally stumped.
