Hi all,
Hope everyone is well
I have recently had a twitchy 'Buy Now' finger when browsing computer components and caved into buying myself an additional Gigabyte GTX470 Super OC to run in SLI with my existing one. Told myself I was going to keep my rig as it is for a while... but we all know how it is I'm sure
Anyway, I've done a few calculations using some online PSU calculators, but I'm a bit worried that my PSU isn't going to be able to supply enough power once I add the additional card. Some calculators results suggest I'm ok, others suggest I'm sailing close to the wind.
What's everyones opinion, do I need to upgrade the PSU? (shame if I do as I've only just bought it but hey ho
PSU : Corsair TX-Series 650w
System Spec
Intel Core i7 950 3.06GHz @ 4.20GHz
Asus Sabertooth X58 DDR3 Motherboard
Corsair Dominator (3x2GB) DDR3 PC3-12800C8
Prolimatech Megahalems CPU Cooler
OCZ 60GB Vertex 2E SSD
Samsung HD103SJ Spinpoint F3 1TB
DVD Writer
Gigabyte GTX470 Super OC Graphics Card
(Rig is basically an Overclockers Black Ops bundle + a few bits)
As for fans, there's 2 x 120mm Akaska Apache Blacks on the heatsink, and 4 x 93mm fans.
So what does everyone think, am I sailing close to the wind installing a 2nd Gigabyte GTX470 Super OC? Or should I send it back and upgrade my PSU first before I start messing with SLI?
Sorry for the long post... any advice anyone can offer would be greatly appreciated. Thanks in advance
System Spec
DVD Writer
