Northern quarter, start about 7 and slowly work your way round, easiest night out ever and all the bars are always full and friendly, depending on whether you want "trendy" or "faux-dive" depends on where you choose. Personally I like a bit of both,
Few places to try out:
Centro
Cord
The Northern
The Castle (a must tbh now they've done it up, especially if you like proper pubs but without the usual drunk locals)
Blackdog Ballroom (good place to start, gets busy later on and a bit pricey)
Simple
The Bay Horse (better downstairs, they have a pool table down there)
Trof (assuming you don't mind a squeeze, head up to the second floor if you do brave it, nice enough bar though)
And if you want to do a bit of dancing to rubbish 90s britpop then TV21 is a good place to end (though it'll make you feel old
main thing to check before you head out is whether anywhere has live music on, as then you'll have to pay to get in. Most places in the NQ do live music some of the time, best place to have a look is probably ents24.com.
Also, you may find that you struggle to get in to some places if there are lots of you. Above about 4 or 5 blokes only I often find staggering the group is the best way to go, if its a more mixed sex group then you shouldn't have any real problems.
Lemme know if you have any specific questions, as the NQ is my normal weekend haunt
EDIT: I just noticed you said 30, scratch most of the places i have just said then. TBH, you're going to struggle anywhere with that many
Think you might need to restrict yourself to the central stuff, try starting at the gardens and go to Kro. It's not exactly great, but its big. Even then you're going to struggle getting them to let you walk in with 30 ppl.
Centro
Cord
The Northern
Simple
)main thing to check before you head out is whether anywhere has live music on, as then you'll have to pay to get in. Most places in the NQ do live music some of the time, best place to have a look is probably ents24.com.
