- 24 Nov 2002
- 38.744281°N 104.846806°W
Goodbye, dear friend.
This simply isn't the case though is it it? The VTOL capabilities of the Harrier make it significantly more appropriate for the terrain in Afghanistan. Whereas the Tornadoes, whilst being more expensive to run, required extending the airstrip at Kandahar, and has result in accidents because it's still not quite long enough for the plan to take off/land properly.The harriers are redundant in most of their original roles these days as we have Tornadoes/Typhoons and of course Apaches.
What was the camera settings when taking that pic?
It looks terribly like that turbine on the refulling aircraft is not turning![]()
Auto mate the outer blades do not turn they just angle the air into the first set of blades behind them ones..
Interesting, do you know the principle behind that?
Give the blades more bite/increase or decrease intake speeds?
I,m Avionics/Electrical mate would need to ask an Engine man. I will try and find one..
"Apparantly they start the air spinning into the turbine and stop blade chattering.....??? " Thats what the A/P (Aircraft publication) states.. What it means i have no idea...
Cheers!Im not an engine man either but my understanding would be if the air was flying straight into the blades it would create pressure, the faster the plane goes the more force exerted on the blades. With the angled ones diffusing the air the pressure will be lower as it will be swirling already. Just my guesstimate though.
that's no use though, pretty grand ornamenti remember a un operational harrier going up for sale on ebay a while back.
Reading that article it says they are being decommissioned with our carriers both of which wil be replaced at the end of the decade, are we really going to be left with no carriers or strike craft for 9 years?
The harrier is a brilliant bit of kit, didn't realise it was 41 years old.
would a former harrier pilot not have the credentials?I could be way off on this but in order to own/operate a private harrier the pilot would require a civilian pilots licence and rating to fly jet VTOL aircraft and afaik the isn't such a rating available...
I would have thought a fair amount counted towards it, especially those who fly within civillian airspace, I'm not sure what they would be lacking, but I'm no expert.I don't know, one would assume you cant just walk out the airforce and demand a pilots licence you have to do the training/tests like everybody else. RAF pilots are great at what they do however its different to civilian aviation, im not going to say easier because the is nothing easy about a harrier but the radiowork/etc is less complicated. Ive heard my father and other pilots joking about ex-military pilots who think their ace because they have X hours of flight time but it counts for almost nothing in the real world and their still basically novices in many aspects.
