startup issue - win 7/s939
13 Jan 2004
Leicestershire
hi guys i have an issue with starting my pc up - once the bios is set etc it works perfectly.
however the bios resets itself meaning a bios error and windows 7 won't load with all the features like internet etc.
why is this?
is it a case of resetting the bios by changing the jumper or taking the battery out?
is the bios loading defaults or is it just losing a couple of settings that you set? could be a flakey battery, £1.50 for a new one from any supermarket, see if that cures this issue.
i was thinking it could be a duff battery just not holding settings as it seems fine if i restart the computer - holds it all. the pc is about 4 years old i think. maybe older.... when s939 were pretty new.
Id does sound like a new battery needed, same was happening to my mums pc. - Normally CR2032!
