- 11 Dec 2010
Strange problem , this will not shut down properly, the fans run for about a minute after windows has shut down. Has anybody else come across this problem?
Daft question - Does the pc allow you to boot into windows and you can use the pc fine.
But the problem is only on shutdown.
Just been looking at the manual can't see anything under thermal management.
got a different psu to try? as daft as it sounds.
