- 12 Oct 2007
My latest piece of must-have kit. Shame about the tacky branding on the front bezel. Other than that, whats not to like?
Building parallel loops with Laing D5 (MCP655) pumps just got easier! RP-450X2 is a dual 5.25" bay reservoir designed for one or two D5 pumps (not included)
Machined from a solid piece of acetal, the RP-450X2 has a thick acrylic window and front aluminum bezel.
Two sets of G 1/4 BSP threaded inlet and outlets appear on the back, designated "P1" and "P2" for each pump. If one pump is used, an acetal blocker is included to occupy the second pump location.
Hi mike gunnz, using the XSPC D750 RES/PUMP no complaints so fare. Would be nice to have some photo's and temp's when installed of Koolance RP-450X2 Dual 5.25" Reservoir please.
Cheer's Oldphart.
i had the xspc version and it just vibrated on the case so i got rid of it.
Not really in the same league in terms of build quality.
Might also have been how you had it rigged up. I've had dual 12v DDCs in an XSPC drive bay res b4 and not experienced much noticeable vibrations.
Pretty tricky to see. So both loops are sharing the same water?
