- 14 Jul 2005
- Bristol
Dab of oppo
This is the main problem. However, if every winter's going to be like this, there's no harm really..Can't justify the £600+ on tyres and £150+ for a spare set of wheels though. Especially as knowing my luck we'll go from a cold snap to a heat wave the second they are fitted!
As for a second set of wheels, you could just use the same rims.
For the sake of a few quid on some steel or cheap but hideous aftermarket wheels
All in all, I'd recommend them, if you can actually find a set.
[TW]Fox;18024031 said:I'd rather drive around on wheels damaged by a tyre fitter than drive around for 50% of the time on mint wheels and 50% of the time on hideous wheels.
Were your insurers happy that you weren't using the OEM sized tyres?
How bad do people find the Pirelli P-Zero Neros in snow?.
And you have to find somewhere to store the unused set for half the year.
