I just wish my mobo fan control was better! It uses tcase temps, as opposed to tcore, so I currently have it set to maintain 45 degrees tcore, tis decent enough. Fans fire up to 100% if tcase exceeds 52 degrees
I think I have the same motherboard as you and I didn't realise it did that. That's annoying. I thought it was a pretty good motherboard too.
On a couple of side notes, does the Megahalems with 2 fans cause any problems with RAM sockets or anything else on the motherboard?
Also I see you have 470SLI, I was thinking of going 6950CF/6970CF/570SLI with this board. What's the spacing like between the 2 graphics cards? How badly does this affect the heat of the first card?
I've got the HAF 932 with a 230mm side fan as an intake fan so should blow over both cards I think, is that likely to help much?
With this in mind is there a better P55 board out there that doesn't have the tcase temp measuring issue but still has good clearance between graphics cards?
I've also read up and it seems my current cooler (CM Hyper 212+) isn't that far behind the Megahalems, so I might keep that and add a second fan to make it push/pull. My 2 questions here are:
1) Do all heatsinks benefit the same amount from push/pull as single fan configuration? (i.e. do they all gain 15% performance)
2) The 212+ is currently using a CoolerMaster BladeMaster 120 fan. These are harder (though not impossible) to come by. Does anyone know if they're any good (I can't find any reviews) or would I be better off replacing them with a couple of Apaches/Vipers/Gentle Typhoons? (Do GTs work as well on heatsinks as radiators?)
Thanks.
