ATI 6870 Crossfire performance
20 Mar 2009
Portsmouth
Hi,
I am after a little advice please.
I have two 6870's in crossfire and I am dissapointed with the performance when using the Dirt 2 benchmark.
All of the reviews I have seen show around 120-130fps in this setup but I can only get around half of that. Now, I can hear you all scream "check crossfire is enabled" but it is. Then you scream "check vsync is disabled" but I have ensured that it is disabled in game and also in CCC. So, I am hoping someone can throw some ideas at me to try.
My current setup is Q9650 on Asus P45 Deluxe, 4 gig Ram, Windows 7 64bit, Catalyst 10.12 (not the new control panel)
I know this is not the latest platform but I cant believe it is responsible for a 50% performance drop.
Cheers,
Hyp
Doubt its the CPU, tho maybe not pushing them as much as it could if its at stock - I have a Q9550 @ 3.825gig and it quite comfortably powers my GTX470 SLI even when overclocked to 6970 levels as good as any i7 setup except in scenarios where the extra thread units on the i7 come into play (which isn't often).
Hi,
Cheers,
Hyp
What res? Ive got 6870 crossfire Q6600 @ 3.6, win 7 64 cat 10.12
Will run the benchmark and let you know what I get.
Yeah resolution would have been handy.
I'm running 1920 x 1080.
My CPU is stock at present (perpares for flamage) as I had some random crashes a while ago and I have not bothered overclocking it again.
I did see the post on the 10.12's, I'll see what bench Walter posts and consider going back to 10.11 if there is a dramatic difference.
First time I ran it I got :-
44.7 ave 36.4 min
Thought that was a little low so I re-checked and applied crossfire is enabled in CC. Re ran the test and got:-
73.6 ave 56.8 min
@ 1920 x 1080 everything on high(post process changed to high) 8xMSAA and vsync off.
44.7 ave 36.4 min
73.6 ave 56.8 min
Your second score is pretty much in line with my single 6870 in dirt 2 but i ran the bench at 1920x1200 with 4msaa. Any how your score is far to low imo.
Ok, I'll chip in on this as I've been wondering the same after looking at the 6870/ 6850 crossfire reviews.
My set up:
Q9550 at 3.7
1x 6870 and 1x 6850 in crossfire or 'frankenfire' as some call it. (Will post in a separate thread about my frankenfire experiences so far if anyone's interested!)
Catalyst 10.12 with preview CCC2
Dirt 2 benchmark in graphics options menu.
1920 x 1080 (my screen is 1920x1200 native but for consistency set your res)
8xaa
All set to 'high' in preset (not 'ultra' as your bench was all set to 'high' no?)
Results:
Crossfire (6870@ stock / 6850 @ stock)
Av. 84
Min. 69
Single 6870 @ stock
Av. 63
Min. 54
Doesn't seem like it's scaling as it should? Drivers???
Even with my frankenfire it should perform at least as good as 2x6850 and it's not when you look at all the Dirt 2 benchies for the 6870/ 6850...
Have you check what clock the 6870 is running at? I think your 6870 is running at 6850 stock.
Might want to OC the 6850 to match your 6870.
But even if his 6870 is downclocking to 6850 speeds it's still not scaling as it should.
Using the high preset 1920x1080 8xmsaa 6870@stock
average = 71.0
min = 52.1
Using the ultra preset 1920x1080 8xmsaa 6870@stock
average = 72.5
min = 54.5
For some reason on ultra i get slightly better performance. I ran both settings 3 times and the marks are still the same. I am still using the 10.10 drivers atm
